Weight distribution
Submitted: Saturday, May 03, 2003 at 01:57
ThreadID: 119902 Views:4701 Replies:0 FollowUps:0
Make sure when ordering that you tell Bushtracker you want to use Weight distribution equipment and get them to weld the jockey wheel bracket further back on the A-Frame so that the weight distribution brackets can be fitted. This will prevent suffing up the galvanising as most people find that they have to grind the old jockey wheel bracket off and move it as B/T normally fit it exectly where the W.D.E. has to go. Another option is to have B/T supply a jockey wheel bracket that can be secured to A-Frame by bolts, that way you can move it to where you want it at anytime.
