Checking Van Lights
Submitted: Friday, May 09, 2003 at 02:45
119921
4947
N/A
It is usually assumed that you need 2 people to check the lights - the brake lights anyway. I just carry a couple of strong rubber bands in the car, and wrap them around the manual over-ride on the electirc brake controller to activate brake lights. If you use your hazard switch, you can check the brake and blinker lights in one pass, and then do a second pass to check the parking/clearance lamps. Phil
Reply By: Noosa Fox - Friday, May 09, 2003 at 02:47
That sounds a lot easier than forcing the brake pedal down with something to activate lights.
558782
