Ventilation Data
Submitted: Friday, Aug 29, 2003 at 23:47
120092
2641
N/A
The following may be of interest.
Whilst pertaining more to fixed installations the Sustainable Energy Institute of Australia recommends the formula below to establish minimum ventilation sizes for battery enclosures.
A (cm.sq) = 0.006 x n x I.
'n' - = number of battery cells (note cells not batteries)
I = maximum probable charge rate in amps.
For example: (say) two by 12 volt batteries = 12 cells
Charge rate maximum (say) 70 amps
0.006 x 12 x 70 = 5.04 sq cm
Thus two slots one at the top, one at the bottom, each
a bit over 5.0 cm by 1.0 cm are indicated by the above.
Note these are minimums - it would seem prudent to double this.
Collyn Rivers
This is
Reply By: Deleted User - Friday, Aug 29, 2003 at 23:49
I calculate I need two by 4.32 sq mm vents for my setup ..... Does that make the "one hole" I have at 12mm diameter work " ..... sure it doesnt !!!! But what do I know ........ I'm not a solar engineer ...... so the one barb ,with a plastic pipe to van exterior, that BTi did, must be fine .........Sigh !!! Anthony
559489
Reply By: Deleted User - Friday, Aug 29, 2003 at 23:50
Anthony,
Ditto,ditto, ditto, amateurs, amateurs,
amateurs.
David
559490
Reply By: Deleted User - Friday, Aug 29, 2003 at 23:51
Anthony
I know you intended to write 4.32 sq cm - not 4.32 sq mm - but just in case any gets confused ........
Collyn
559491
Reply By: Deleted User - Friday, Aug 29, 2003 at 23:52
Woops !!! Your're right Collyn ..... missed it !!! It's all this packing for Cania and last minute jobs ...... Square Centimetres .... NOT Square Millimetres .... Lucky I didnt go for the .... siemens/henry/farad/coulomb..... type thingamybob !! Regards Anthony
559492
Reply By: Deleted User - Friday, Aug 29, 2003 at 23:53
Enjoy Cania - would have loved to be there!
Collyn
559493
