Fridge problem
Submitted: Friday, Nov 14, 2003 at 07:52
ThreadID: 120228 Views:3202 Replies:1 FollowUps:0
A friend of ours has a 150lt 2 door, 12 volt Danfoss compressor fridge (Vitrious or similar brand name) and is appears to be running correctly but then when the thermostat cuts the compressor it often only stops for a second or two, and sometimes 15 to 20 seconds and then restarts again. This causes the condensor inside the fridge to ice up and hence the temperature inside doesn't get cold enough. He has had service reps check it and they say there is nothing wrong with it, when there obviously is. Because it is running almost continuously, it causes problems with his batteries as the solar imput cannot keep up with power used by fridge. We turned it off, cleaned all the ice out of it, and then restarted it on a low thermostat setting but it didn't make any difference, it just ran continuously again. Has anyone got any ideas what the problem might be? Brian
Reply By: Bogger John - Friday, Nov 14, 2003 at 07:54
We had exactly the same problem with the fridge in our Bushtracker that we
collected last July. When we got back from our trip we took it down to BT
and after investigating Peter found a bad connection was causing the
problem. We haven't done another trip yet so hope that really has fixed
it. Suggest your friend has all the electrical connections in the back
checked.
AnswerID: 560119
