BT Upper rear lights
Submitted: Friday, Mar 12, 2004 at 04:55
120443
3891
Luvntravln
Turist When we met you mentioned something about one of the Boggers - was it you? - that put tri-lights on the top rear of the van similar to the lights on the bottom rear. Can you give me some more information? Part no, size, etc? Thanks, tgintl/jay
Reply By: Turist - Friday, Mar 12, 2004 at 04:57
Jay the brand of the lams on the BT is Narva.
they also produce a matching one piece set, (brake,tail,flash) that is around half the size of the original used on the Bt.
Sorry, don't have part number but nearly all auto aftermarket shops stock Narva.
The smaller set looks good when high mounted, in balance you could say.
I have seen a full size set high mounted and it looked "oversize" and out of balance with the van design.
The high mounted second set of lamps gives good visibility to following traffic and does not get so heavily coated in dust.
561486
