Power Upgrade
Submitted: Sunday, Mar 21, 2004 at 10:20
ThreadID: 120465 Views:4261 Replies:4 FollowUps:0
Dear Turist,
We have been trying since we joined the group in 20/12/03 to chat on the open
Forum without success ( not very familiar with group chatting and
computers)
So decided to try contacting the chatter who seems to
try keeping the others in order.
We live in Newcastle and have a GU Patrol 4.2 Turbo
2002 pulling a fully fitted out 16 ft.Bushtracker weighing 2.1 tonnes empty.
Last year we spent 3 months in Queensland with the BT
attached, plus 3 months on Cape York without the van ( left it at Port
Douglas)
The Patrol performed quite well without the van but was
very slack when we wandered up and down the Great Dividing Range.
We intend leaving again in early May to travel around
Australia and occasionly leave the BT so that we can go into the real backblocks
as we did on Cape York.
We would like to get a bit more KW and torque so that
we can pass a few ' 27 Chevs on some of the outback long straights.
No doubt this has come up for discussion on the forum
at some time but we have not seen it.
Our questions are;
Is it better to just have it tuned or
Tuned plus enlarged exhaust or
Tuned plus enlarged exhaust plus enlarged rotor via
MTQ
Have any of the Boggers had any experience in this
field ?
Any experience with Aussie Tow Mate device that
indicates on the dash when a tyre is going down?
For the person going to Cape York....If you want to see
the beauties of the Cape it is far better to leave it somewhere south of
Daintree and really enjoy the place.
We enjoy the forum and hope to be able to chat in the
near future but haven't much time left to decide what alterations are necessary
to pass that '27 Chev.
Kind Regards KIRKO
1925
Reply By: Turist - Sunday, Mar 21, 2004 at 10:22
Kirko
We pulled our BT #1 with a 4.2 TD Patrol and had the same problems you describe.
The van was an 18' model so we were pulling upwards of 3 tonnes.
I had a diesel tune done by the mob on the southern highlands, about $700.00 worth but no significant improvement.
Then had an aftercooler fitted, I think it was Safari.
Significant improvement in power and pulled the van with ease.
The BIG BUT.
But it overheated badly on hills, especially long ones where engine revs were up and road speed and airflow down.
It would boil on a good climb such as from the coast up to the Vic high country.
The aftercooler fits in front of the radiator and restricts the air flow.
After much discussion with the supplier who would accept no resposibility I did the best thing I have ever done.
Purchased an F250.
I do not think that apart from an engine swap to a Chev diesel that you can overcome your problem.
The 4.2 TD just doesn't have the grunt for our job.
Best Regards
AnswerID: 561649
Reply By: Luvntravln - Sunday, Mar 21, 2004 at 10:23
Turist Do you have a snorkel on the F250? Cheers, tgintl/jay
AnswerID: 561650
Reply By: Deleted User - Sunday, Mar 21, 2004 at 10:24
Maybe not, I have read many good reports about the Dtronic piggyback
computer on Nissan TD engines.
I have recently installed a Dtronic on my 2003 LC100 4.2 TD and 'oh what
feeling'. Torque has increased from 430 nM to 530 nM all the way from 1200
rpm to redline. kW also increased, can't recall how much.
Towing the BT is a different experience now.
David
AnswerID: 561651
Reply By: Deleted User - Sunday, Mar 21, 2004 at 10:25
Kirko, As Bob has said .... Slapping an intercooler in front of the aircon condenser which is in front of the radiator then upping boost/fuelling to increase engine power up by 10 -20% puts a heavy load on the radiator. Intercoolers come in two configurations ... one is Tube and Fin and from memory allows more airflow through the intercooler ( less restriction of air to radiator) but is a less efficient at intercooling. The other is Bar and Plate .... with good intercooling but harder to pass air through. You might think that putting a bigger radiator on would solve the problem but it wont do its job if you cant get air through it .... it just takes longer to overheat because your heating a larger volume of water ..... The solution to intercooling and not slapping a huge intercooler on the front is what is called a "water to air intercooler". In simple terms it is an intercooler inside a box and in this box is water/inhibitor mix like in a radiator so the water cools the intercooler not air ... much more efficient as the thermal efficiency or water is 30 times that of air (from memory). This boxed intercooler is so efficient that one required to intercool a cruiser turbo diesel is about 500mm x 200mm x 100mm and can be placed in the engine bay near the intake manifold at any angle or orientation. It also stops another problem in front mount intercooler, that is, pipe friction from the big pipes that go all the way from turbo to the front, into intercooler and then all the way back to the engine intake. When you try to pass large amounts of air through a pipe the walls of the pipe hold air by friction and the centre stream of air moves faster the air near the pipe leading to more inefficiencies. A water to air overcomes this by pipe work only being about 500mm long as against 2 metres. Also the smaller intercooler core has less friction across the area between intake and outlet as it is a quarter of the size. The water in the water to air is cooled by a small separate baby radiator mounted in front but being much smaller offers far less restriction of air to the engine radiator. Water is circulated by a electric water pump in the heater hose size lines going from the intercooler to the baby radiator. If this pump ever plays up or you blow a water line the car can still be driven, you just dont have intercooler cooling until fixed which reverts the engine to how it is now .... you are still able to drive with safety. Cost is comparable to a front mount I believe ..... ???? Might be worth investigating ??? Also ... Because you are pushing a turbo diesel engine a bit you might consider fitting an exhaust temperature gauge in the exhaust to keep an eye on it when pushing up hills or ranges. If it gets a bit hot you can see it and back off a bit ..... If running an auto box you might also include a trans temp gauge for the same reason. VDO now make suitable gauges for this purpose and are a reasonable price. Recently a friend of mine placed a temp gauge in his Patrols auto (Petrol) and we discovered 110/120 c in the auto .... far too high ... after fitting a fan forced cooler it runs around 80/90c now ..... towing. Regards Anthony Explore this Great Land ...Do it Easy ..tow a Bushtracker
AnswerID: 561652
