Reese Hitch
Submitted: Friday, Apr 02, 2004 at 08:56
120499
4174
N/A
Hi Boggers Well, tomorrow afternoon we'll round up the boys and head off to Devonport to catch the boat to Melbourne. Once we arrive it will be straight around to meet our BT for the first time at the Melbourne Caravan Show. We think we have gathered everything we will need for the inaugural trip and have read past posts from Anthony and of course checked off the "On the Wallaby" checklist too! It will be great to meet up with some fellow Boggers at the show, some of whom will also be attending the rally at Copeton in September. Gadget-1, deaf nomads, tgintl, swanwood and rockgoc have all indicated they will be there. Any other Boggers who will be around, we are meeting at 10am at the BTi exhibit this Saturday 03 April 04. Can't believe it is finally our turn to pick up our van after months of reading others joy and trepidation of hand-over and pick-up! We will be leaving Melbourne on Tuesday for a two week trip through Bendigo, along the Murray, Broken Hill, Cameron Corner and who knows from there. Head back over Bass Strait on Anzac Day. Thanks to Angie for the good wishes from London. Rod, Dominique and the boys
Reply By: Noosa Fox - Friday, Apr 02, 2004 at 08:58
Lindsay & Jenny, On the Caravaners
Forum there is a member Camecguys and they can be contacted at sales@caravanacc.com.au and are located at Kogarah. They should be able to help you. Brian
561872
Reply By: Deleted User - Friday, Apr 02, 2004 at 08:59
L&J, A couple of quick questions .... What vehicle are you towing with ? If possible measure the width of the A-frame at the front of the the a-frame plate ? Coupling type on the BT ? 100mm chassis or 150mm ?? Regards Anthony Explore this Great Land ...Do it Easy ...Tow a Bushtracker
561873
Reply By: Luvntravln - Friday, Apr 02, 2004 at 09:00
Anthony, At the Melbourne Show the Hayman Reese people that own Trail Boss that imports the Reese from the states said that their standard fix for the Reese/AT35 problem is a 20 mm spacer. tgintl/jay
561874
Reply By: Deleted User - Friday, Apr 02, 2004 at 09:01
Jay, As I said the only AT35 you can use a spacer with is the Gen 2, as it allows you to lengthen the thread length of the attachment stud because it has a drilled hole for (and uses) a 3/4" bolt. You then use bolt in reverse as the coupling will accept nut end not lengthened stud . I'm puzzled as to how they can fit a 20mm spacer under it and still have enough thread length to allow nut/lock washer to gone on .... ??? Spacer = 20mm, Reese head collar = 25mm, Lock washer = 7mm, AT35 nut = 25mm, total 77mm. Thread length is approx 65mm. The spacer only needs to be about 14mm and you could use a 3/4" unc nyloc nut to eliminate the lock washer ...gaining you the extra thread length ...just (maybe) !! The nyloc nut might be wider though because of its half donut area having to hold the nylon. Regards Anthony Explore this Great Land ...Do it Easy ...Tow a Bushtracker
561875
Reply By: Luvntravln - Friday, Apr 02, 2004 at 09:02
Anthony Ah !!! The silliness of engineering !!! [smile] Exploring we will, experimenting we will go, hi ho the derry o, look out AT-35 - machining we will go! tgintl/jay
561876
