Wind Deflector
Submitted: Tuesday, May 11, 2004 at 09:12
120571
3973
Luvntravln
Hi For those interested in the wind deflector that has been discussed in various threads, I have put a diagram in the photo album that I received from the manufacturer with the following explanation: "I have attached a drawing of the wind deflector on the van to show the measurements needed for the antenna and top lights. If your antenna is closer to the edge than 200mm we will need to make a cut out in the deflector for it. If your top lights are higher than 1350mm from your bottom lights then you will need to move these lower before we are able to
fit the deflector. The length of the deflector will be 2280mm, if you would like to check. We have found that this is the standard for the newer vans." tgintl/jay
Reply By: Bushtracker Buck & Babe - Tuesday, May 11, 2004 at 09:14
Jay, Have you shared this information with BT so that they can build the van so that the deflector can be fitted? If so, then we can just say to them - "We want the same as Jay" rather than go through the whole process again. Angie 80 sleeps to go
562189
Reply By: Luvntravln - Tuesday, May 11, 2004 at 09:15
Angie I sent the same information and diagram to BT. The are familiar with the deflector as it is installed on Conrad's 23' and Brian Fox's 21'. tgintl/jay
562190
