cure for bulldust
Submitted: Tuesday, Oct 05, 2004 at 18:13
ThreadID: 121474 Views:4806 Replies:4 FollowUps:0
Can anyone remember what the miracle is for curing pink sikaflex back to white after exposure to bulldust?
Angie
Reply By: Cobradave - Tuesday, Oct 05, 2004 at 20:00
I would suggest any mild solution containing bleach or citric acid.
AnswerID: 565007
Reply By: Noosa Fox - Tuesday, Oct 05, 2004 at 20:43
The suggested method before was a citrus based cleaner. If you have access to a high pressure cleaner, that does the job also, BUT the high pressure can allow moisture to get into places it is not meant to and the decals don't like it.
The other option is to just leave it, as it shows that you are using your BT for where it was designed to travel, and it will only return the next time you travel in those conditions. Wait until you get over to WA and into the REAL red dusty conditions.
AnswerID: 565008
Reply By: Deleted User - Wednesday, Oct 06, 2004 at 21:34
try thr new orange oil based cleaners available from the s/market,,they are really good
AnswerID: 565009
Reply By: Deleted User - Wednesday, Oct 13, 2004 at 09:03
We always use Wax and Grease remover. It is available from Auto shops that sell paint . sometimes called Prepsol Pyrites Pete
AnswerID: 565010
