Measurement Please
Submitted: Thursday, Oct 14, 2004 at 05:38
ThreadID: 121506 Views:4518 Replies:3 FollowUps:1
Could I get someone to tell me the internal height of the van. Please
Bonnidowns
Reply By: Deleted User - Thursday, Oct 14, 2004 at 18:25
G'day Bonnidowns,
Mine is 1960mm approx. The latest might vary from that ? I think BT42's BT is 10cm extra because of his long leg bones !! [smile]
Anthony
AnswerID: 565103
Reply By: Bonnidowns - Thursday, Oct 14, 2004 at 20:17
I take it that you can vary the height, does this create many problems with total outside height restrictions?
Bonnidowns
AnswerID: 565104
Follow Up By:- Thursday, Oct 14, 2004 at 21:09
The roof thickness stays constant ... so any increase or decrease will affect the overall height of the BT on the outside !!
A 10cm increase wont be that bad with trees, bridges or overhangs but you'd have to be aware of it.
Its always a good idea to measure your BT height when you get it home and write it on a sticker and place it on the sunshield. When a height restriction comes up via a sign you can flick the sunshield down and see clearance ...
The aircon is usually the tallest area ..I used a broom stick to transfer this height to the edge of the BT and dropped a tape down to ground.
Obviously all aerials should be on knockdowns for travelling.
Anthony
FollowupID: 843966
Reply By: Noosa Fox - Friday, Oct 15, 2004 at 03:37
The internal height of ours is 1.976 meters, that is floor to ceiling. The air conditioner and speakers hang down a little. Our overall external height to the top of air conditioner is 3.0 metres. I know BTi have changed the internal height of some vans to suit tall customers, so I would suggest that you talk to BTi if you have special requirements.
AnswerID: 565105
