Bushtracker 18.... your water bladder thingy?
Submitted: Tuesday, Oct 26, 2004 at 23:02
121536
10214
TripnTaps
Hi Anthony,
Did a search for 'water bladder' no listing under that title or in the body??? Not under 'thingy' either !!!
Have decided to get one of those super duper bladders that you discussed before. Gocs have got one but are off air at present ...so I have to pester you instead. (Full Bladder Grin!!!)
Can you please advise details of same and where you got it from.
Ciao
Helen
Reply By: Deleted User - Tuesday, Oct 26, 2004 at 23:29
Reply By: Deleted User - Wednesday, Oct 27, 2004 at 01:32
You could get a purpose made one from ARB.
Then you would be able to have one in your vechicle as well.
regards
macka
565189
Reply By: Deleted User - Wednesday, Oct 27, 2004 at 03:57
G'day Helen,
I have the same as Ernie ...dont forget to mention 10% discount for Boggers if you get it from Glascraft Marine in Brisbane. Cost was about $125 for the 150 litre one ?
I did the same with the large outlet ...sealed it with a 1-1/2 inch poly cap. Just cut the barb bit of the large outlet so you can get the poly cap on ....
I used a hacksaw with a fine blade and filed the area a bit and deburred the edges ..poly cap went straight on .... it fills and drains well from the small barb as Ernie said ...
Macka,
The ARB ones are mainly meant for placing in the inner guards etc ??? The ones I saw anyway .... ??? These Turtle Pak bladders we have are really strong stuff ...it then has a truck tarp woven cover over that again ..(Tautliner).
Turtle Pak has bladders approved for Sewage (black tanks) and diesel fuel ...
Anthony
565190
Follow Up By: TripnTaps - Wednesday, Oct 27, 2004 at 18:33
Thanks Ernie, Macka and Anthony for the info on the bladder.
Appreciate the advice re setting it up right too.
Helen
844010
Reply By: Deleted User - Wednesday, Oct 27, 2004 at 19:17
Helen if you have a sucker hose you can suck straight from the portable tank to the pump. I carry it on the roof rack and connect the sucker hose straight to it without the need to fill the water tanks. Depends on the situation at the time and this method is another option. I've never tried it but you should be able to gravity fill the onboard tanks from the portable on the roof rack without the need of a pump. Probably a bit slow but who cares anyway if it takes another bottle of red to do it hey?????
Ernie
565191
Follow Up By:- Thursday, Oct 28, 2004 at 00:38
Nah, Tony they have one that sits across the foot well of the back seat about 70 litres if memory serves me correctly.
Macka
844011
