Generator Slide & Acoustic Box
Submitted: Wednesday, Dec 29, 2004 at 21:30
ThreadID: 121677 Views:4946 Replies:1 FollowUps:0
Geni Slide and Sullage Hose Storage Pipe Photos have been added to my photo album for replying to Motherhen's querie on The Generator Acoustic Box, and to add to the KISS Storage photos in previous post.
The box is made of 8mm ply and is lined with 12mm self-adhesive aluminium foil backed dense foam sheeting which I scrounged from the local recycle shop. The box is covered on the outside with lightweight carpet. The vents, exhaust extractor and flexible exhaust hose are all available through your nearest marine supplier. The box is 390mm wide, 460mm high and 620mm long and fits neatly onto a 39/40 litre Engel Fridge Slide.
The generator can be run with vehicle closed up (Except for rear window for exhaust pipe and fresh air intake). The only noise from 5m away is the slight hiss of the exhaust air coming out. Operating temperature inside the box was 50 degrees C when I had 25mm foam lining. Whilst Honda reckon 50 deg. ambient is OK, I'd rather see it operating with lower temp. So, I am replacing the 25mm foam with 12mm stuff and this should increase air flow around the generator, hopefully running cooler. If this doesn't lower temp, I will add a 12 v computer fan to blow cool air in.
I have heard of others using this principle and would be keen to hear of their experiences. By the way, the generator in the acoustic box is only used when power is needed, and when there are nearby campers who may be concerned about noise, or if there is a nasty ranger prowling in a national park. Otherwise, it can operate in the open or out under the van.
The short leads are for connecting power leads, and one of them is made up with 15 amp wiring and a 15 amp female plug for connecting to the van power inlet.
The EU20i Honda runs the air con with ease. I think I can recall Anthony saying that it's best not to run your charger at the same time, switch off the inverter, and limit other power usage to lights, radio or TV. (Don't use electric jug, hair dryer or toaster while the air con is running off the geni.)
Obviously, if it's hot enough to use the air con, there's probably plenty of sun for the solar to keep the batteries up.
Judy (Motherhen), I hope the pictures and the above info will help.
Cheers........Rob and Liz
Reply By: Bushtracker - Friday, Dec 31, 2004 at 21:16
Unfortunatly, Bushtracker cannot do any kind of work like this, so please don't ask... Ha! End of humour..
ADR compliancing on fire hazard, elevated heat in petrol fumes environment... On and on. Would suggest it is dangerous at best.. Computer Muffin fan relay shuts down, heat elevates in a petrol environment... Ouch!
Necessary on Diesel applications... Yes... But on a light, super quiet already, Honda?? Please be careful friends....
Might not be what you want to hear, so again I sacrifice my popularity to give you a sound concern, rather than maybe what you want to hear.... But I would strongly advise against such housings on air cooled petrol generator that could suck in its own petrol laden fumes into an internal slip ring, however minor sparking potential, generator environment; if the cooling fan packed it up and quit.....
Kind Regards, your friend at Bushtracker
AnswerID: 565568
