Tip # 54, The Lone Ranger is Back! A big one requested:"Off-Road Towing Tips"
Submitted: Monday, Aug 01, 2005 at 22:12
ThreadID: 122145 Views:6219 Replies:9 FollowUps:4
The arguments for coming back were overwhelming, both here and on the Owners Forum, thank you, and I will try again....
Many have commented that they appreciated the Towing Tips for Newbies, but would like one for Off-Road as well…. So by request, here it is… Mind you, it could be nearly endless, but here are a few: First of all, do the exercise of reading the 28 “On Road Towing Tips” Tip # 21 from memory in the Archives… As much of that relates to off-road as well… These are some specific off road parts from experience, with examples of the kind of “poo” you can really get into, and how not to get into that situation in the first place…. There are extreme Off-road Tips already on this Forum, and others, this is just a few for towing related problems…
1) “Walk it”: When in doubt, you need to get out of your truck and walk ahead. I know that is inconvenient at times, but not doing it can have some serious consequences. In my Tip on Feb 25, 05 “Tall Tale from the Lone Ranger” on the Hi-lift Jack value, I told you about an occasion on driving on a hard crust over quicksand up north, only to find an hour later in the middle of the recovery, that I was well below the high tide mark !! Now for those of you that have read that I will not bore you by repeating the story… But here is another: On the back side of Gregory Downs, is a destination called “Lawn Hill” Gorge… Through it and pushing on is the headwaters of the Gregory River, and there is a dirt track out of the “Riversleigh” there that follows the Gregory downstream. About 50 km down that track, well out of the range of most touring, we followed a cattle track down from the road to the Gregory for the night. We went through the normal steep banks of a river that floods, through these “flood channels” down on to the Gregory itself. This was a magic spot, one of those you dream about, a peninsula of gravel bar out that the river went around on three sides, and had bits of firewood branches here and there… Perfect. I drove down on it and turned around, but there was water running under the gravel and it was like greased pebbles and I hesitated as soon as I started the U turn: Down I went all the way to the axles…!! You need to walk a suspicious or different bit ahead, feel the ground, as it is a lot better than the hours of recovery!!
2) “Walk it in reverse”: You KNOW there is nothing back there but tall grass. But it is disheartening to hit a 700mm high round boulder, crushing your steps, and having to pull them out in reverse with the winch and hammer them into shape… (Yea, done that too! A dubious record..).. When in doubt, have a look, even when reversing, get out and at least have a look. Walk it before you back up in the tall grass…
3) “Sound the ground”: Another time I was looking for an overgrown track to the “Lost City” of caves on a Station out west. I came to a low spot in a valley between limestone cliffs on sand, and the surface was dry, but wheel ruts were wet and there had obviously been rain… The thing to do was get out and jump on the ground a bit, to sort of sound it out for solidness.. I would have discovered it was a bit mushy like, sort of soggy. That would have told me there was water running under the sand at that low spot, quicksand of sorts with a dry crust on top. So did I? Nope, not me, I drove out on it with a tonne of diesel fuel in a trailer, and buried her all the way to the running boards, didn’t I… You do stupid things, tired, and in too big of a hurry… Lessons learned hard in the Bush… More of my misspent youth… So, sound the ground when in doubt..!!
4) “Get wet”: I dropped a LandRover over the steep edge, and had water running over the bonnet in about 1976, because I did not want to get wet and walk out in the water to sound the depth first… The wait for help was not pleasant, and you really feel dumb too… Just watch for Crocs up north. But udder dan dat, walk it and get wet.
5) “Greasy driving”: On the black soil country, when it has rained for over an hour or two, it starts to get greasy. You can still often make it out if you don’t wait too long, specially if you have diff-locks or L.S. Diffs. It varies in the terrain, and the amount of rain, but from my experience the black soil on the dirt track gets less than an inch an hour in water penetration turning it to black grease…. So for the first few hours you are alright, and not cutting up the track, just very slippery. After eight hours or overnight, you had better just stay put for a few days and let it dry out, as even if you did get out you would be doing the wrong thing cutting up the road.. But in the first bit, or a light rain, you just have a fish-tailing greasy driving problem… Often you will get up to a certain speed like say 40kph, and it will start fishtailing around, and you will have to slow back down to say 20kph until that fishtailing stops. Alternately you can turn up your brake controller “Gain”, so when you just start down on the pedal, the brakes come on the trailer first, and pulls back on the tow vehicle without the tow vehicle brakes coming on at all.. What this does, is immediately cure any fishtailing action, by just applying the brakes in the van alone to pull it back dead in line behind you, to stop any fishtailing… Understand? The top part of your pedal puts on the caravan brakes first, (with the “Gain” turned up), without putting on the tow vehicle brakes at all.
6) “Jack knife”: The same sort of a problem can occur on a curve… The van could break loose on traction in the mud, and start to slide off the road pulling you off with it!! IMPORTANT: This could happen in mud, but also ice, snow, even gravel. If you are in slick conditions and in a curve and the caravan starts to break loose and come around.. TO PUT ON THE VEHICLE BRAKES CAN MEAN THE WORST CONDITION AND THAT IS THE TRAILER JACK-KNIFES UP ALONGSIDE… This is a real issue in slick conditions, and another reason to reach down and turn up the gain on your brake controller, so the brakes on the caravan come on first, pulling it back in line with the tow vehicle; so that if you continue down the pedal to brake the vehicle the van is already dead behind you and pulling you up as the vehicle brakes come on…. If you do not clearly understand this one, Email me and I will send you more elaboration!!! It is very important…
7) “Nut Cracker”: Watch how close to right angles, you back the van in a tight spot… You can crush your power mover jockey wheel, or hit other equipment if you push it over too far with some vehicles… Be careful as you pinch it up onto the rear of the tow vehicle, to see what can bind up in the jaws of the nut cracker..
8) “Watch the traffic behind”… Don’t make them angry, that forces them to pass you in frustration when it is not really safe… Pull over, be courteous, let them get by you.. On dirt tracks some Locals will be travelling at a higher speed than you, they being in familiar ground, where you are in a strange place with a van on the back and going noticeably slower… Pull over and let them by, make a good name for Caravaners instead of a bad one. And it is safety as well, as they might pass when it was not so safe, just out of frustration..
9) “Elephants everywhere”… Cattle are a major reason to slow down…. When you are approaching a mob, figure on a 1000kg bullock just in that thicket that is going to panic and run out in front of you to get back to the herd as you approach… It will happen. They will jump out in front of you, and when they do they are as big as an elephant! Just like in Africa, you slow down in the herd as you do not know when one will panic and try to get back to the Mob as you approach… Cattle are no different, and hitting a big bullock is about the same as an elephant in disaster! Mind you Camels are real big too, and even the out west big Red Roos are too big to hit!! I have seen some stand about 6’ tall.. Keep in mind that the “Herd Animals” need the herd for security, and will bolt across the road at your approach to get back home… The dangerous bit is the same here as in Africa, the dangerous spot seems to be as you approach the herd, and the one in the thicket panics and bolts out in front of you to get back to safety… OK?
10) “Right of way to Road Trains”: Tonnage, major tonnage, in a hurry, earning a living, frustrated with “Bloody Tourists”, it does not matter who has the “right of way”…. Again it is like Elephants in Africa…Don’t argue. Stay clear and let them by…. Pull over and let them pass, pull over on head to head and let them through…! Don’t Argue!!
11) “Grates”: Watch out, some cattle grates are quite steep on one side or the other, and the same goes for jump ups and dips cut in the road for drainage…. Go slow enough to see and react, particularly in bad weather…
12) “Throw out the schedule” No you don’t have to get there tonight. Don’t push it, remember to slow down and smell the roses, because that is what you are doing this for in the first place, right? Remember? There is an old adage about stopping a putting a cup of tea on when you hit a problem… Not so silly… A lot of times you can save yourself a lot of grief if you sit down and think about how to tackle the problem for a while… The main thing is just to slow down and enjoy the process, and get away from the City Lifestyle of being too Goal Oriented…
13) “Spares” This topic has been gone through pretty well in other places, but shovel, jack, winch is nice, tyre repair kits, spare belts, hoses, basics for the donkey… I could go on but this is covering old ground, and the list is as extensive as your pocketbook or carrying capacity is…
14) “Snatch blocks and shackles..” Get an education before using these! Basically a snatch block breaking loose off a tree is like a great 8 tonne slingshot going off and will cut anything in half it hits, or the cable slices, if there is a strain on the winch…. The same for shackles, like on snatch straps… If they break they can go clear through a truck with the elastic tension off the snatch strap under massive loading…. Join a local 4x4 club to learn the safe use of recovery gear, as I would have to write a book here on this to explain it without the use of pictures and such… You know “a picture is worth a…”. that bit… Do your homework, so you take the potential tragedy out of travel… Also learn the 4x4 basics from your local Club about things like padding a winch point on a tree with a padded sling or something so you don’t ring-bark the tree and kill it…! No I am not a Greenie, this is just good Bush Sense… And the right thing to do…
15) “Tell Someone Responsible”: If you are going wwwaaaay out back of beyond, make sure someone knows when you should be coming back out of the Bush, and which way you went…. If you are broken down, stay with the vehicle. Almost all recent deaths are because they found the vehicle but the people had tried to walk out in the heat…. Yes radios and sat phones and such are nice, but, make sure someone reliable know where you went and when you are coming out of a big desert or real rough run somewhere remote….
16) “ Medical kit” … Again covered elsewhere, but a necessity…. Mine is very extensive. You can always get cookbook coaching over the radio, if you have the gear to make a difference, and a Senior First Aid Certificate is not a waste to have.
17) “Spin the wheels”: As a rule, once you completely break traction, sitting there “pouring on the coal” on spinning the wheels going nowhere, only gets you deeper into the poo…. Stop, have a cup of tea, look at the situation, slow down and think…. Oh yea! I forgot to put it in 4x4, or Oh yea! I get to try the diff locks.. Or try backing up a little and get a run into it a bit to get through…. Sometimes it is a little forward and reverse “rocking” to get out of it… But in general, breaking traction and spinning the wheels is just counter productive….
18) “Leave off the diff-locks going in”….. Keep something in reserve in bad muck…. You can usually get out with the addition of one little thing like Diff-Locks… Or letting the tyre pressure down for a larger footprint and traction…. And you can always get out in reverse…. The exception to the rule would be like one time when I was on the back track out of William Creek to Coober Pedy. There were a few 20 to 40 Metre Bogs at that time. When you can see the end, and need to get through, then give it all you’ve got, Diff –Locks and all… And with a manual, know what gear to use, as in maybe third gear low range on some vehicles, or second gear in high range on others… Get the power and momentum going and stick with it, have the right gear selected going in and do not try to change gears if you can avoid it… A speedy power shift is great, but a blown shift is loss of forward momentum and can mean BOGGED AGAIN…!
19) “Worst case” And mind you I have only had to do it once, but you can always un-hook and drag it out by the tow hooks in the rear of the van… I have usually only used those tow hooks to pull out other people… The Jockey wheel could get damaged, so use some discretion here. If the wheel is down, in mud you may be able to crank it down and slide it… Or you can put the gears in the right direction and have someone steer it with the handle walking behind… BE CAREFUL, but as long as you are clear of it and not down hill from it, and not under it, you should be alright with this manoeuvre…. But again, I have done it, and successfully steered the van by hand with the jockey wheel while being pulled out in reverse…
20) “Think about the Winch” If you are going to push the limits, going into a BOG, think about your bail out plan…. Where would you hook the winch to pull you through??? Remember, “discretion is the better part of valour”… Have a back up plan… Once in Nicaragua, at the bottom of a crater at the end of a good cattle truck dirt track I wondered about getting to the lake in the centre. I had the good sense to walk out to the waters edge on the 100 Metres of clearing. As I walked out, the ground seemed to feel a bit funny. About half way to the water, I stopped and jumped up and down, only to see to my HORROR, that the whole ground moved like jelly for 20 Metres!!! Never seen it that bad anywhere else in the world!!. There was a good hard crust, but underneath it must have been a water logged colloidal jelly like clay. If a vehicle broke through the crust is would have gone down to the running boards with nothing to winch to, and nothing to jack on… If you are in doubt, look to see what would bail you out before you get in too deep… You will get enough adventures anyway, without getting yourself into the really stupid ones.
21) “Pick a good spot to have an Audience”. On the way back from the Nationals, National Reining Horse Championships in Sydney just the middle of July, I did not want to park 19 metres of truck on a narrow neighbourhood with dog and horses on board at 7 AM on Sunday Morning while I went to Maccas. So there was an empty field next to the McDonalds, and to be a nice guy and not park my impatient horses and dog wanting out, I pulled out on it… I Did not follow my own rules about walking it or anything did I ?? Little did I know but what it was a re-claimed swamp, with dredge fill, after six weeks of rain, with a nice coat of grass over it!!! Well, the Circus that ensued had the whole neighbourhood out to watch. Ha! Nothing like the Experienced looking silly, Too… Embarrassing ! Anyways, before you have the entire mob watching you try and manoeuvre your van in tight spots in your arrival at a remote camp, spend a few sessions and some time in an empty Shopping centre parking lot until you are good and confident at putting your van in and out of tight spots… Saves the red faces later… Know how to do the basics of nice neat backing into spots and three point turns and backing and filling and jacking over tight, before you have the whole camp watching you under red faced pressure…OK?
22) “Cutting Corners”: Keep in mind that there can be something in that bush you are cutting the corner on… Once in the N.T. I cut a corner and heard this shrill buzz and all of a sudden the van weighed about 20 tonne. There was an old abandoned well casing in the bush, that someone had welded a gate hinge to. It cut the corners off the alloy body armour checker plate and cut a groove about 1 ½ Metres long. Never mind it would have ripped the whole side out of a normal van and the body armour saved the day, it still is not pleasant to put “Battle Scars” on your van. Keep in mind you cut corners, and there might be something in that bush…
23) “To Tired to Think Straight”… Most of the silly things happen when your judgement is impaired by being tired. Realize that, and think about it twice when in that state. Do not take the chances, it is not worth it… Reconsider, and second guess yourself, when in a tired state and forced to make a judgement call or decision….
24) “Watch the High Centre”: Keep in mind the maximum distance to your tail shafts (drivelines) when venturing over logs and drop offs… In one 4x4 Club there was a notorious hill with large holes and humps, called “Tail Shaft Hill”. Look at your vehicle for high centre weaknesses. And on my Ford, I looked at and protected the Transfer Case with an added leaf spring cage to keep from high centre damage on a rock or log as I climbed over..
25) “Know Your Horse”: It pays if you are handy, to know the abilities of your tow vehicle… For instance, can you lock up the transfer case, and drop one tail shaft to run out on the other differential, in case of damage? Can it be modified to do that? These simple types of little modifications could save a huge recovery bill in the right circumstances. Get to know what you can and cannot do with your horse…
26) “Snorkel”… Some of these things are not just a style or fad… A petrol engine can survive a water drenching with a proper dry out… But take a slug of water in the intake of a high compression diesel and you have killed the engine. And you do not want to plunge into a metre deep creek crossing without cooling the engine down first. Water splashed all over a hot engine can cause serious problems to the engine… Cool it down first, check the depth, close the water tight door on the van, and then proceed on that deep water crossing. A metre deep of water is not a problem… Just not a high current like on a Weir or fast running creek, as the reduced weight on the wheels with you partially floating can mean you get swept in.. OK? Anyway, the fan can pick up water at only about 400mm deep on some vehicles, and you do not want to blow that water all over a hot engine. It can be done even with a petrol, if you plastic bag seal the distributor, or have a treated plug wire system, or disconnect the fan belt for a short run, it is just more difficult with petrol… But don’t let the “easy” of the diesel run you into trouble with a hot engine and cold water. Big No-No! For instance it can immediately seize up a hot injection pump and shear a shaft… Cool, no problem..
27) “Gum Tree Blues”: I am hesitant to park under big overhanging limbs of Gum trees. I have had two branches last year fall on trailers out at my horses. They are heavy, and seem to drop branches without notice, particularly during a drought or storm… In the drought it might even be a survival mechanism, but it can sure be a problem if you are under them with your Bushtracker!! I for one will always park out in the sun, for solar input, but also a saved spot for me under a big overhanging gum tree branch, will stay vacant. A few of the species of Gum trees are notorious droppers of limbs, Cabbage Gums, Blue Gums, etc. I don’t trust any.
28) “Steep Driving”…. As mentioned in a previous bit about getting through a BOG, you need to know what gear is best in your own personal 4x4… You need one strong enough not to run out of torque on the really steep bits, but not too strong as to be slow so you don’t have “Power-on traction”… You need to have the strongest gear selected before your run up. Almost all disasters come from having the wrong gear selected, running out of steam, and having to try and power shift on the fly.. Good if you can do it, but a disaster in the making if you blow the shift, lose you forward momentum, and having to back down to start again… It is all too easy to blow it on a slippery steep back down process. You want to know your vehicle and be in the right gear. It is not such a problem with Automatics, just get into low range and she will power shift for you.. But with Manual Transmissions the selection of the right gear is all-important. It is usually 2nd gear in High Range, or 3rd Gear in Low Range, but you need to know what works for you and your van. Backing down with a van on the back is very rough.
29) “Where the Rubber hits the Road”: There are three things to remember in off-road work, tyres, tyres, and tyres… Three hundred kms up the Bulldust track on the west side of the Cape near the beginning of the rainy season??? You had better have some lug type tyres, with cavities that carry enough weight of mud that they will spin the chunks of mud free with the centrifugal force of each rotation and bite again…. Mud Terrain…. If you have street tyres, or milder type of All Terrain, close to the wet season, maybe consider not pushing your luck…. That is the sort of thinking you need… Want to run up the riverbank from Roper River Bar, chasing Barra?… Not in street tyres…. And rate your tyres on Side Wall strength, as that is where you are vulnerable… Trucks cut deep ruts, and when they dry like concrete there are often sharp rocks hanging out as you fall into the dried ruts… That and dry hardwood staking are the “tyre eaters”…
30) “Shoot the Goat”: Australian Strine for “Shut the gate”… Leave all gates as you find them, leave no trash, watch fires carefully, possibly none in drought areas or fire danger, bury any business, all the proper campground etiquette you already know, so others in the future will be welcome too ! In short, leave the area behind caring for it as if you owned it, and you will be welcomed back on your return…
31) “Too Tall Jones”: Watch you overhead clearance. I in my Career, have done the big stupid a few times… Once at a Vehicle Registry in about 1994, I hit the low part of the overhanging roof with my Electrolux air unit and luckily just cracked the outer fibreglass housing… But I have found that you are particularly vulnerable when backing into somewhere. You are so busy looking at your clearances, many fail to look up a that big hanging branch… I tore loose a solar panel once with that exercise…
32) “Tyre Pressure”…. I cannot tell you what to run. It is a matter of what tyres? And what size of van? And what size of tyre? And what load? And what corrugation? And how deep the corrugation? And what speed? And then on a Gazetted road, the tyre pressure too low might be technically illegal… All I can tell you, is that on my last van on the severe corrugation, low was about 25psi hot and about 20 psi cold. But that may not work for you.. That was on 285 Mud Terrains to match my Ford F-250. You have to judge the bag in your tyres in relation to your load and the road conditions. You are only too low, if the wheel starts to hit into the bag of the sidewall on a severe rut edge. This you are going to have to judge for yourself, but cushion the van with lowered tyre pressure… Too high a pressure, and you will shake the van and contents to hard. That is the cause of much damage to appliances, and why one person will have it happen and others not. Usually too fast, or too high of tyre pressure, or both… And then of course the Driver is usually in denial, and it is all Bushtrackers fault… Ha! Anyway, this is an important feature and an “important learning curve” for you, to treat the vans right off-road.
33) “Dusty” There are two important Culprits, the rear window and the Four Seasons hatch… Someone just Ordered a van and said “Can we get extra care not to have the rear window rubber seal over the screws like we saw on our Friends Bushtracker that leaked bulldust?” I explained that “It did not leave here that way”. I showed them that what happened is that the top hinge had filled with dust, and when it would not crank closed, someone has gone outside to “help” close it.. This stretches the hinge, and drops the hopper down lower, ruins the window, and it will never seal properly again. There are many solutions, from air foil dust blowers on the roof, to cleaning of the hinge, to duct tape over the hinge to keep the dust out, many choices in the Bulldust; but if you force the window closed with dust in the hinge it will never be dust proof again. Another factor is that of late, people have been taking more “Expeditions” with other Bushtrackers in Convoy. For instance two 21’ Bustrackers and one 20’ Bushtracker just went on an expedition to the Cape… When in convoy, you hold back to the edge but you still have dust hanging in the air. We build the vans with the Four Seasons Hatch as far forward as possible to keep it out of the dust line, as it has to be a none sealing double skinned gas venting hatch by law. But if you are following just on the edge of bull dust in the air in Convoy, you may want to cut a piece of foam to fit the opening to seal it up just for that trip… I have also closed my watertight outer door over the gas vent in the door, and pushed in a strip of foam on the top to keep out the bulldust. We build the most dust proof van in Australia, but these are the three exceptions that can still cause problems in the right or wrong circumstances…
34) “Speed”: What is the hurry? Slow down on the corrugation. If you are marking up the contents in drawers and fridge, if you travel too fast, you will start to break things. Too hard of travel breaks shelves in fridge doors, hinges on cabinets, things like that. Tyre pressure is important, but also speed. One person in a Convoy was always a half hour behind. The others always had to wait up for them… They both arrived at the same time, but the one that ran ahead had breakages, where the one that travelled slower did not… What is the rush? Again do not be goal oriented so much… Some of the greatest discoveries were when I least expected them, and had time to poke along and have a good look around, not just getting to the pre-planned place…
There are countless more ideas, most you will get along the road from fellow Travellers… But there are also many “Tips” to read up on here in the Forum… On Diff-Locks, Hi-Lift Jacks, Jacking up the van, many subjects you can get by looking in the Archives and doing a search for the word Tip in the Subject Matter Box.
Kind regards from the Ranger, still up on the ridges, tryin ta look afta ya!
Reply By: Fosssil - Monday, Aug 01, 2005 at 23:10
Hi Steve...
Welcome back...thank's for the info which many/most folks will find very interesting.
foss
AnswerID: 566881
Reply By: Fosssil - Monday, Aug 01, 2005 at 23:23
Just adding some thoughts here and probably many/most folks would feel the same.
Speaking for myself, It's good to see Steve back and I am sure most folks would agree, so please ...lets make sure we keep him here this time...I doubt we would be given another chance.
Many Newbies like myself (and probably some oldbies...lol) need to gather all the advice we can...then its up to us to sort it out, and use what we need or what we think suits our requirements........so lets make sure that Steve is welcome, feels welcome and hence feels like contributing .......please.
Thanks for listening.
foss
AnswerID: 566882
Follow Up By: Bushtracker - Tuesday, Aug 02, 2005 at 00:18
Very Kind, Foss.... Thank you for your help...
FollowupID: 844822
Reply By: Deleted User - Monday, Aug 01, 2005 at 23:54
Hello Steve, first welcome back !!! and good to see your back in the saddle. I won't take too much of your time Steve as reading the other threads a lot of people including Vivian and l are glad you are back with your tips to BT owners and like us owners of the future.
Look forward to meeting you and the gang on 6 Dec 05 when we do the factory tour on our way through to Melbourne.
Again keep up the tips and don't worry about the 'knockers' who go out of their way to upset you; remember we out number them and appreciate what you have to offer 10 to 1, cheers Terry & Vivian
AnswerID: 566883
Follow Up By: Bushtracker - Tuesday, Aug 02, 2005 at 00:19
Thank you Terry and Vivian... It is nice to know the time is well spent...
55 tips down, 200 yet to go, and then I will have to go scouting around...
Cheers.... stg
FollowupID: 844823
Reply By: Whatsnew01 - Tuesday, Aug 02, 2005 at 03:29
Good to see you back on deck Steve. Quality advice is always appreciated.
Roy & Judy
AnswerID: 566884
Reply By: TRAVLN - Tuesday, Aug 02, 2005 at 05:08
Welcome back Steve!! Nice to have you around again with your tips and advice.
Carl & Karen.
AnswerID: 566885
Reply By: jandm - Tuesday, Aug 02, 2005 at 06:51
Steve
Great to see you back. You have my welcome and appreciation as well.
Jim
AnswerID: 566886
Reply By: Agnes Lifestyle - Tuesday, Aug 02, 2005 at 07:30
Great to see your back. Thankyou. Your tips above made me want to get back on the road tommorrow.Have to get Ron out of the surf first.
Dianne and Ron.
AnswerID: 566887
Follow Up By:- Tuesday, Aug 02, 2005 at 15:47
Great to have you back Steve that tour of the factory is looking close
Macka
FollowupID: 844824
Reply By: Tellem Bugrem - Tuesday, Aug 02, 2005 at 18:35
g'donya Steve,
Yep, I knew to walk it but succumbed to the late-in-the-day "there's a good camp just around the bend" syndrome, when we bogged the rig in dry sand at the Three Mile Camp on the Finke River, north of Glen Helen. Also hadn't deflated tyre pressure to 20psi ! A good samaritan then joined me in forgetting that a stick is not an appropriate medium for joining two snatchem straps. He had the misfortune to cop the stored energy in the tailgate. We shared the excess on his insurance, and remain good friends.
NEXT TIME.....WALK FIRST.....check and adjust tyre pressures for conditions......AND, if you still get stuck and require the use of two snatchem straps, use a rolled up newspaper in the loop-through-loop joint.
It is an embarrassing experience, but one we should share with others in the hope that they will remember the tips.
We subsequently enjoyed 5 nights at this great free camp, using it as a base for day trips to Glen Helen, Redbank, Ormiston, Ochre Pits and Serpentine. The helicopter ride at Glen Helen is spectacular, the entertainment at the Resort Bar was excellent, and well worth the $6.50 a beer to to enhance the enjoyment.
cheers...........Rob and Liz
AnswerID: 566888
Reply By: Bushtracker - Tuesday, Aug 02, 2005 at 21:48
Thank all of you for the many kind remarks, and it is really good to hear from people that are so "switched on".... I consider it an Honour and a Pleasure, to be in your good company...
Kind Regards, from da Ranger "back on up on the ridges..."
AnswerID: 566889
Follow Up By: macka the wacker - Wednesday, Sep 21, 2005 at 08:17
Thanks for your replies Steve.
FollowupID: 844825
