Thetford & Webasto
Submitted: Tuesday, Apr 11, 2006 at 07:37
ThreadID: 122595 Views:4152 Replies:3 FollowUps:1
Learned the following today while at BTi getting ready for our trip to WA.
Thetford - our casette was no longer registering on the green to red guage when full. Reason: When I emptied the casette I always TWICE put fresh water into the casette and gave it a rigorous shake. Problem: when you shake, rattle, and roll you cause the magnet that interfaces with the guage to come loose. BTi just learned this from Thetford recently. As usual the after market service from BTi was second to none - a new casette.
Webasto - whenever you start the Webasto you are supposed to run it for 20 minutes on full high to burn off any carbon buildup during the startup. Then, turn it down to your preferred thermostat setting.
Happy traveling.
On 17 April we along with Keith and Phil Batson and families, and Stella Voolstra depart from Byron Bay for Steep Point "sorta" through the center.
Will keep everyone informed of our progress now that we have a MiniMax USB broadband connection wherever we have a CDMA signal.
Luvntravln
Reply By: Oldperc - Tuesday, Apr 11, 2006 at 20:39
Excuse my ingorance, where's Steep Point?
We're heading to Birdsville and then south in a couple of weeks, we like traveling against the flow!!!
David
David and Ann
'I'am so proud of you poppa'
AnswerID: 568333
Follow Up By: Turist - Tuesday, Apr 11, 2006 at 20:54
The most westerly point of mainland Australia.
FollowupID: 845720
Reply By: Oldperc - Tuesday, Apr 11, 2006 at 21:05
Thanks Bob
Silly me, should have guessed given they are departing Byron Bay!!
Have located it on the map.
regards
David
David and Ann
AnswerID: 568334
Reply By: Luvntravln - Wednesday, Apr 12, 2006 at 08:13
Regarding the replacement casette, I should have made clear that we are still within the BTi warranty period.
Luvntravln
AnswerID: 568335
