TIP # 138 Report on New Winch, 16,500 lb and Temperature sensor protection.
Submitted: Thursday, Jan 04, 2007 at 03:02
ThreadID: 123159 Views:3816 Replies:0 FollowUps:0
There is a new winch available from Warn, (actually 2). There is a smaller one for smaller sized vehicles that has a built in air compressor, have a look. Not sure I am too excited about it as it is a smaller winch about 8000#, but the other one is really a nice machine… A much larger 16,500 lb one for the likes of larger vehicles like Fords, that has a Motor Temperature sensor and a warning light LED on the winch control hand piece. It only costs about $100 more, and you get a bigger winch than the 15,000, but also the temp control safety device… There are a couple of other interesting improvements, like the control head that is cast alloy instead of plastic, and a general fell of a more robust workhorse winch. Now Tip # 15 reviews all winch choices, Hydraulic, Power Take Off, and Electric and they all have their strengths and weaknesses. I have owned all of them, and broken all of them, or at least stalled them under full dead loads, and there is a trick to running the electric winch far beyond its capacity with water cooling per Tip #15 on “Winches”… This new Warn, just goes down that path, with the temperature sensor and control in the hand piece, and it all fits together really well.
There is also a Cradle available that suits the winch, from Warn, that fits inside the big Steel Bullbar from Ford. Many of you get the Nissan style Bullbars from ARB and TJM, because Ford did not bring in the winch cradle for the Ford Bullbar. At least one Bogger, has taken the Ford steel bullbar back off of his F-250 because the cradle was not available. Well it is now, and it is on my new F-350. Readily available, also from Warn....
For those of you that are not familiar with the various types of winches and how you break them, here is a reprint of TIP # 15: Winches (service, duty, type, and how they break...Ha!)
For the sake of credibility, I give you the reference point of my first hand experience. I have 35 years in extreme 4x4 use in extreme conditions hunting deer, elk, bear, in North America, game patrol overland in Africa, and three years in Central America, 17+ years of travel in Australia, as well as the part time and full time living on yachts where many of the Bushtracker concepts come from… Now some background on the primary security of winches… Again, I will qualify myself so you take this with its due credibility: I have owned around a dozen winches of all three major kinds, on a variety of vehicles including two military vehicles. I currently own five vehicle mounted winches. I have the largest personal 4x4 in Australia, a Dual Cab Mack, with a 20,000 lb hydraulic out the front and a 12,000 lb warn out the back.. (Yea I know I’m crazy, Ha!) I also have two Landcruisers currently, an old 1989 Sahara that I cannot bring myself to part with, that has 330,000 kms on it and has now been fully restored; with a Warn 9000 lb. I also have a 100 Series with a 10,000 lb Warn on the front. My last Ford had a 12,000 lb Warn on it… My new (last F-250) Ford has a Warn 15,000 (and now my new F-350 full American Import has the 16,500lb). I have an extreme amount of experience with 4x4 to the limits of possibility in hunting, prospecting, adventure, and exploration; so here is the voice of experience on the matter, and I digress for a moment for the benefit of those that do not fully understand the difference; then I will get into the proper priorities of choosing which is the best…
Winches: There are basically three types. PTO (Power Take Off), Hydraulic, and Electric… PTO is about the strongest, as it will go to and exceed it’s design limits, where hydraulic and electric often stall and do not go to their rated capacity for a number of hydraulic and electrical shortfalls.. PTO is shaft drive to a geared winch. It’s strength however can be it’s downfall. There is supposed to be a shear pin in the shaft and u-joint drive that is the weak point; However, I have broken two of them without the shear pin going… In 1973 I had a 1968 Ford F-250 Military with a PTO winch on the front, and with the front nose down in a bog pulling obliquely I sheared the weld on a u-joint yoke… In 1980, when a 48’ yacht hit the beach and started to break up, we hired a “tank retriever” from the guy that supplies military vehicles to Hollywood and it was there in 5 hours to catch the next low tide… The hull was breaking up and sinking in the surf due to ballast, so we only had the low tide interval to salvage. This was not enough time to unbolt gear, we had to just rip it off with the tank retrievers enormous winch under the headlights of the local Four Wheel Drive Club cheering us on… We did things like ripping out the engine right off mounts, with so much strain up and over the gunnel that when it broke loose it shot up right out of the wreck and landed with a thud on the sand.. Anyway, in the end we broke the bull gear on that winch.. So, PTO is great, but a bit expensive and very hard to route the shaft drive with u-joints from the PTO to the winch on modern vehicles. It is a daunting task to route the solid shaft drive without the high ground clearance of vehicles like Military, older Ford 4x4, Dodge Power Wagons, and such.. Sooo, yes it is strong, almost too strong for its own good, and very hard to put on modern vehicles…
The next is Hydraulic… Now this is great, PTO or belt drive or gear drive, hydraulic pump and flexible hoses to a hydraulic motor on basically the same winch… This however is the most expensive….. And hard to do it right. The hydraulic reservoir on my Mack is large, as the pump moves 72 litres a minute a engine speed of 1000 rpm… On a smaller winch with modest power, the pump can still move 30-35 litres per minute, and it will heat up and smoke the oil if you do not have a big enough tank. This is probably the best winch, if you have room, and a very large pocket book. Mine will go until it actually stalls pulling down dead trees and such to get their fall right with the chainsaw. Some of the good hydraulic winches are under-rated and will go til they stall without breaking anything.. Good, but expensive… And there is the problem of a reasonable tank reservoir so the oil does not heat up too fast..
Now for what is practical, most cost effective, and the Tip for its shortfall: Electric winches are cheap.. They will run until they stall, and seldom break. The will also run without the engine running, where the other two will not.. I have run mine under water, while salt water is a no-no, being electrolyte conductive on its own, I have run mine under fresh water nose down.. Maybe water did not get into the motor, but I have heard other similar reports. Anyway, the biggest short fall is heating up the motor… If you have a long pull, you are limited to a few minutes, as to run time on the motor before it heats up.. With the engine at 1000 rpm, the alternator will catch up charging the batteries while you change out winch points, but the motor takes forever to cool… So here is the Tip: About 100 km in the mountains S.E. of Springsure I was out on the back of a Station in 1997 trying to find a legendary place not seen in many years.. It was a jumble of rocks and caves that only a few old Horsemen knew about called the “Lost City”.. I had a 1.5 tonne off-road trailer full of supplies, on the back of a stretched 75 series Landcruiser with diff-lock, high lift suspension, LSD front diff, 12HT Turbo diesel, and the works.. Fearless!… Or so I thought.. Until I broke through the four inch dry surface crust of sand in the bottom of a little canyon, and sunk into the slosh almost quicksand of an underground river; and sunk up to the floorboards. It took many full length reaches of cable and snatch block to double the power of the 10,000 lb winch, and another recovery cable, set up many times with about 45 minutes of winching, to plough through the mud to firmer ground. Now the average run time to overheating is only about 5 minutes… Major Problem… So I put a 20 litre jerry can of water just inside the bull bar, leaning against the bonnet of the Cruiser, and with a spare small drain valve (like on the water tanks) stuck in the end of jiggle siphon, I had the motor cooler. I jiggle siphoned the water out of the jerry can, and then throttled down the valve so it only just let out a small stream of water onto the Warn winch motor body, dead in the middle so it ran all over the 12v motor. I stopped it after a while when re-setting the snatch blocks for another pull. This gave me the longest and hardest run I have ever heard of with a 12v winch. You might know the drill, shovel ramps, wood in the hole, ploughing mud deep enough to use the front tyres (while turning in gear in low range), they were only a use as rudders.. Ha! While some conservatives would critique this situation as foolish, it is the price to pay once in while for adventure and exploring of the kind that I do…
On getting back home days later, I though surely the winch motor or gear drive was damaged or severely worn, as it all got hot even with the water cooling… So I removed it and shipped it to ARB in Brisbane. They disassembled and inspected it, and then put it back together and shipped it back to me, no parts, only the $132 shop time for inspection. The stretched Landcruiser was eventually retired to ten passenger Tourist buggy on Frazer Island, with the same winch still in place… Ha!
Snow, mud, sand, slosh, the practical cost effective answer is still electric. While hydraulic is superior, it is many times as expensive, and there is the tank problem… There is a unit out there that runs off the power steering pump (which is hydraulic), but I have heard many poor performance reports, slow, lack of rated power, etc… I can’t see how it could run to my demands, as the pump and volume requirements when you are really in the “poo” are quite large.. Soooo, the electric winch, when aided by the water cooling discovery of mine on the motor, is still the best option. On short pulls, for most people, no worries about cooling.. But one major shortfall has always been power (alternator catches up fast as you reset the gear) and overheating if you have accidentally driven onto a crust or swamp or broken through the dried crust of river gravel down into the slush.. Ha! So if you have to do a long pull, the water cooling seems to work where many have burned up winch motors or had to wait an hour for it to cool each time before another winching set, and I will do the water cooling again…
Summary:
The cooling trick can get you out of a jam... And this new Warn Winch with the Temperature sender in the hand control, is headed down the same practical track… It is on my new F-350 for anyone that wants to have a look at one… The best price we have found is in Sydney, for winch and cradle to suit the Ford Bar. Send me email and we can provide the source. Even with freight, it was cheaper than in Queensland by far. They deal in bulk….
Cheers, your Friend at Bushtracker......Hi Oh Silver!!
