Satellite broadband connection in the bush
Submitted: Sunday, Mar 18, 2007 at 06:20
123413
8995
7
Grumblebum & Dragon
We will be looking into systems for accessing the internet when we are well outside CDMA range and in the bush. Required use is monitoring the world markets and investments and trading on the US market.
I have seen such advertised in the caravan trade mags - does anyone have experience?, recommendations? or 'don't touch with a barge pole' suggestions!
Cheers John
Reply By: Motherhen & Rooster - Sunday, Mar 18, 2007 at 06:28
Hi John - I don't know how you would go when 'on the road' but the Govt has subsidies and a push to get everyone onto fast Internet, so they can deal with the ATO etc. Check out the Govt website -
http://www.dcita.gov.au/Article/0,,0_4-2_4008-4_110837,00.html
Your own ISP should have info on their website too
| Motherhen
570851
Reply By: Kingy - Sunday, Mar 18, 2007 at 08:59
Hi John
I have been looking for an affordable solution to remote internet access for the last few years and to date am no closer than when I started. I trade ASX equities and cfd's and being a short term trader tend to close all trades when we go wandering in the BT, but there will come a time when we go wandering for good and I want to be able to trade anywhere, anytime.
I did have a 2 way Vsat broadband setup here at home before we could get ADSL and that was ok but definately not portable. The oyster sat mob in Brisbane initially said that they had the technolgy coming to do a 2 way broadband connection with their self tracking dishes that some BT owners use for Sat TV, but I believe that is not going to happen.
One possible solution I did stumble across a few weeks ago was inmersmart bgan system [URL= Site Link but the data price I was quoted at the time was $5/MB. If I contain myself I can keep my usage down to about 500MB/month so we won't be getting that sytem until they can contain their price structure.
For now I am using my NextG phone plugged into the laptop and whilst I have been more than happy with speeds and connectivity, again for heavy data usage, it is a bit costly and of course, you are restricted to the towns for coverage.
Hopefully sometime soon we will see some confluence rather than divergance between technology and price when it relates to remote internet...
Peter
570852
Follow Up By: Grumblebum & Dragon - Friday, Mar 23, 2007 at 02:50
Thanks Kingy, That was useful. Likewise we plan on doing some trading puts and calls on the ASX and the S&P indexes in the states. More often than not I am well out of CDMA range - except here at Lorna Glen where we have satellite broadband installed.
I am sure the day will come when such recievers will be no bigger than and dinnner plate plugged into the laptop.
Cheers John
847369
Reply By: Bushtracker Buck & Babe - Sunday, Mar 18, 2007 at 20:03
hi john,
we have just picked up the nextG wireless broadband internet deal from telstra.
buy a little USB port plug in for $299 and then go on a plan to receive the net. Ours is a 12 month $84.95 per month for 1GB plan but there are a variety available including a faster one for 1GB around the $120 per month mark. We are happy with our speed.
You are still restricted to access whilst you have signal but the map for Australia is not too bad and I like the luxury of using it in our van on our own computer. I think the systems will only get better so it might depend on when you are going to need it. I would leave it until closer to your departure time so you get the most up to date.
With the Telstra NextG you can get cheaper deals if you lock yourself into a 3 year contract which we were not prepared to do.
Angie
570853
Reply By: Fosssil - Sunday, Mar 18, 2007 at 23:55
Soon, Maxon will have a multi computer modem router for NextG... Now that interests me because I have found that my wife and I have very different internet requirements... So when we go away, we hope that device is available so that we would connect via laptop wifi to the router which would be set up in the Caravan.
It may even send the signal to the Tow vehicle which will be very handy just to have one access point and internet access anywhere around the van..
Run mouse cursor over middle "coming soon" item on the Maxon home page " target="EOF" class="lbg">www.maxon.com.au/
fosss
570854
Follow Up By: Fosssil - Sunday, Mar 18, 2007 at 23:59
Try this page and if this gives an error just go to maxons home page
" target="EOF" class="lbg">www.maxon.com.au/index.php
847370
Follow Up By: Fosssil - Monday, Mar 19, 2007 at 00:07
@#$%$#...Er...Yes...well the page does not want to come across without error probably due to the Java script load requirement of their home page.
Just click on Home under the error message for the correct page.
fosss
847371
Follow Up By: Kenso - Monday, Mar 19, 2007 at 22:24
Sounds like the go Foss, just rang them but they have no idea what the capabilities are will know more in a month or so. On the shelves May -June (maybe).
Kenso
847372
Reply By: BushBoss - Monday, Mar 19, 2007 at 00:01
Hi John
check out www.vansat.com.au
or phone 07 49555879, They are in Mackay. They should be able to help
Regards Lance
570855
Follow Up By: Fosssil - Monday, Mar 19, 2007 at 00:21
Problem is Lance that their system requires CDMA...and hence you must be in a CDMA area..I think that service is designed to get higher speeds than normal CDMA internet speed...and just uses the CDMA connections for you to give the internet your requirements.
I had exactly the same setup for my home internet for two years before I got ADSL..only instead of the CDMA modem which is only used to provide the upload of internet browser instructions and hence does not need to be fast unless you have heaps of uploads.... I had an ordinary dial up phone to send my instructions...
May as well have the Next G setup...cheaper, faster and more future proof and much less bulky, and soon to have the new maxon modem.
fosss
847373
Reply By: Grumblebum & Dragon - Wednesday, Mar 21, 2007 at 02:04
MMM ....not looking good. Most of the systems appear to be phone based which is not much good in the 'real' bush. Vansat advertise but their system is salellite coming in and CDMA going out - why would you bother!
We have a satellite system at LG which I organised as soon as I got here - and the office picked up the tab.
I have a colleage who uses a fully portable system on his laptop - but the price is huge per MB.
We are planning on using it for trading on the S&P index - which is more 'Minute Trading' than 'Day Trading'
Cheers John
570856
Reply By: Bushtracker Buck & Babe - Wednesday, Mar 21, 2007 at 07:29
John, I had heard that CDMA was going to be phased out at the end of the year. So the NextG seems to be the next big thing.
Ours is not connected to the phone in any way. Remarkable the technology available today isn't it?
Angie
570857
