Window problem inside Annex
Submitted: Monday, Apr 30, 2007 at 05:44
ThreadID: 123556 Views:5195 Replies:5 FollowUps:2
Hi all,
I have looked around and read a lot about the Aussie traveller Coolabah annex and think we may have a unique problem. First of all I need to state that we have found the outfit fantastic. It has withstood months of strong gusty wind and a lot of rain. Over much use I have gradually got better in the construction and usage so that it really is an excellent second room to the van.
Just yesterday though as I was cleaning the windows of the van I discovered that the two windows that are inside the Annex have a dirty spotting as if it had been sprayed with fly spray. It covers the whole window and refuses to come off using any of the detergents we have currently. Why?
Experimenting with different cleaners I found that a multi purpose 'Orange Clean' degreaser made a good difference. So far have only tried it on a small spot due to fear of damaging the window.
Any comments or suggestions appreciated.
Buck
aka Ivan
Reply By: Turist - Monday, Apr 30, 2007 at 05:49
Angie it could be a form of mildew.
Try to polish it off with a plastic polish such as Mothers plastic polish.
Most good auto spares shops stock it.
Makes the plastic look great and repels rain and dust as well.
AnswerID: 571335
Follow Up By: Bushtracker Buck & Babe - Monday, Apr 30, 2007 at 05:54
Hey Bob,
Windows are too high for Angie and I just could not get her up on the ladder.
Thanks for the tip mate.
Ivan
FollowupID: 847709
Reply By: Tellem Bugrem - Monday, Apr 30, 2007 at 17:49
G'day Angie & Ivan,
Plexus is the go for BT windows, even to the extent of removing scratches. It also creates a protective film, making removal of any substance much easier. The product was specifically developed for cleaning windows of F18 fighter planes. You can get Plexus at Motor Cycle shops (used for protection and cleaning of motorbike windscreens)........a spray can....for about $20.
Cheers.........Rob
AnswerID: 571336
Reply By: Oldperc - Tuesday, May 01, 2007 at 02:55
Car polish is the go. Try Turtle Wax. Polish and removes scratches.
David
David and Ann
'I'am so proud of you poppa'
AnswerID: 571337
Reply By: Bushtracker Buck & Babe - Tuesday, May 01, 2007 at 04:39
Thanks Boys, I knew someone would be able to help my fella out.
Angie luuuuurves nice clean windows.
The Babe
AnswerID: 571338
Follow Up By: Bushtracker Buck & Babe - Wednesday, May 02, 2007 at 18:39
= AND THE RESULT IS =
I did not get to try the plexus but settled for the high quality polish and the stuff came off. I suspect as your suggested Bob that it was some form of mildew. Elbow grease and mild detergents certainly did not shift it. I am sure the plexus would work as have used that before on motor bike helmet visors.
= NEW PROBLEM =
These two windows are now better than the rest which means someone is suggesting I have another job.
Ivan
FollowupID: 847710
Reply By: Dickie Nee - Friday, May 11, 2007 at 07:46
I would not use a Orange Oil base cleaner as it is a very agressive solvent and solvents are out on this type of window.
AnswerID: 571339
