Bike Carrier
Submitted: Monday, Jun 11, 2007 at 04:19
ThreadID: 123733 Views:5728 Replies:8 FollowUps:1
My wife and I are planning to take mountain bikes when we take the 'Tracker to some locations. Has anybody mounted a bike carrier at the back of their 'Tracker and able to advise how best to do it?
Vince
Reply By: Freewheelers - Monday, Jun 11, 2007 at 18:46
ni vince
dust is a big problem if going off road
lotsa people have them at the front in various configurations just needs to be stong & allow access to other goods stored there
we have one bike which stands vertically one a rack on the roof of our cruiser this gives some clearance problems ends up same height as the van plus you need a lader to access but bike stays clean & you can spot your vehicle in a supermarket car park
ps bikes are really useful & a great way to look around
Stephen & Deborah
AnswerID: 571900
Reply By: Sundy & Cyclone - Monday, Jun 11, 2007 at 19:37
Hi, we have been taking our bikes too originally on a rack at the back of the van but that was too dusty & too worrying. We have now moved our generator box to the rear on a substantial mounting frame and moved the bike rack to the "A" frame and added a couple of wheel tracks to locate and secure them.
The result is that they don't get as dirty/dusty, they are visble, travel better and are protcted by the B.T. stone guard, anyway that system works for us.
Regards Judy & Tony.
AnswerID: 571901
Reply By: Bushtucker Man - Monday, Jun 11, 2007 at 20:28
Hi Vince,
I would check on the legal side of carrying bikes at rear of the BT, in some states its not allowed.
Have heard of bikes falling off and causing accidents.
Regards Stan
AnswerID: 571902
Reply By: The paca people - Monday, Jun 11, 2007 at 23:35
Hi Vince,
Our 18" BT had a 500mm extended A frame which helps but I have just fitted parts of a Fiamma 2 bike rack across the A frame. We carry one large frame road touring bike for 6' tall me and a smaller hybrid frame bike for 5' 2" Christine.
The Fiamma I purchased was supposed to have its underframe U bolted to the caravan's A frame and, of course the U bolts were too short for a heavy BT A frame. Also we do not need the "tilt foward to give access to the front boot " feature.
I used the 2 aluminium extruded channels and wheel securing straps plus the inverted U aluminium bar to which the bikes are secured.
Works perfectly. If you want pics just email me rosedene@westnet.com.au for details.
Cheers Martin B
AnswerID: 571903
Reply By: Noosa Fox - Tuesday, Jun 12, 2007 at 05:40
When we were staying on a Kimberley Station last year they had 3 bikes still on a bike rack that had aparently fallen off the rear of a van without the owners knowing.
I have seen some of our members who have bikes fitted on top of boxes across the draw bar.
If you can afford it have a look at www.onyerbike.com.au where they have folding full sized mountain bikes advertised. We bought 2 a few months ago and have taken them away with us folded in their carry bags, where they are secure and well away from the hazards of dust.
AnswerID: 571904
Reply By: TroopyTracker - Tuesday, Jun 12, 2007 at 21:08
Vince,
I'm using the same rack as the Paca People. If you do a search you should find a thread were I posted pics and you can see how we sorted out the short u bolt issue. Steve wondered whether or not the rack would stand up to outback travel (as did I). We've done more rough stuff since we've had the rack than before hand and it's still in one piece....so far. The fiamma bag is a waste of time and we had ours refunded. Dust is an issue and we have a design on the chalk board for an almost totally sealed bag.
5 mins with some degreaser/hose/grease works in the mean time after dusty conditions.
Matt
AnswerID: 571905
Reply By: Rob n Son - Tuesday, Jun 19, 2007 at 03:51
HI Vince,
We thought simple was best, we had a standard bike carrier(tongue mounted three bike carrier) mounted at the rear of our last van (Trakmaster) and were unhappy with the dust collection even though they were enclosed in a special bag the dust still got in and made using the bikes very difficult.
On our new BT we simply had a steel bracket with a hole same size as the ball mount welded to the A frame where some have a centre jerry can holder then mounted the same carrier with the top arm leading forward .(Bikes remain behind the stone guard)
We do not use the bag and yes they do get a bit of dust on them but no where near the rear system.
Rob P
AnswerID: 571906
Reply By: Cowcockies - Tuesday, Jun 19, 2007 at 08:21
Vince,
We use the same system as Rob n Son. Bolted on, with a high tensile bolt, the same size as a 50mm ball bolt so we can slip in the standard Hayman Reese tow bar tongue and transfer the bike rack to the car for trips away from the BT.
David & Sue
AnswerID: 571907
Follow Up By: Brownie 59 - Tuesday, Jun 19, 2007 at 23:12
David & Sue,
Your setup sounds ideal - any photos?
I'm a wanna-be BOGGER and am cathering all the info possible.
Mark
FollowupID: 848041
