Gross Combined Mass revisited
Submitted: Saturday, Oct 27, 2007 at 02:25
ThreadID: 124155 Views:21377 Replies:7 FollowUps:11
Is anyone really towing legally?
Does anyone have the specs on the F250 SuperCab 7.3ltr TD 4x4? Ford website no longer has the specs, and the best I can find is as follows:
Gross Combination Mass 7369kg
Kerb Weight 3146kg
Gross Vehicle Mass 4219kg
Kerb weight is the same as TARE = empty!!
GVM = everything you put into it including yourself and your fuel.
GCM = GVM+BT
While we all thought that the increase of the tow capacity from 3500 to 4500 was great, that didn't increase the GCM.
Previously 3146 (kerb wieght) + 3500 (maximum tow capacity) = 6646 so that you could have an F250 payload of 723kg to reach your maximum GCM. 144kg went to fuel and 150 - 200 kg went to you and your passenger; not much left!
What good did the 4500 give us since after fuel and people we only have 300-400kg to spread between the F250 and the BT?
I am hoping someone can tell me where I have misinterpreted the numbers!!
Having just increased the "lift" with additional leaf springs from Carrolls I am advised by an engineer that Carrolls has recommended that I can significantly increase both GVM and GCM.
The downside is that if I take the GVM to 4500 I will have to get a light truck license (that's not so bad); however, only persons with a light truck license will be able to purchase and use the Effie after the increased rating. That would severly limit the market.
Your thoughts?
Jay
Reply By: Luvntravln - Saturday, Oct 27, 2007 at 04:09
It has been suggested that my GCM figure is too low and that the figure is 9000+.
If someone has the correct GCM it would be appreciated if you could post the correct number and the source.
Thanks, Jay
AnswerID: 573229
Follow Up By: Andy1 - Saturday, Oct 27, 2007 at 16:19
Jay
Carrolls must have a somewhat vivid imagination. I have had discussions with two engineers with a view to increasing the GVM and the issue, according to these guys, is braking capability not suspension.
Andy
FollowupID: 848749
Reply By: adams44 - Saturday, Oct 27, 2007 at 06:08
Hi Jay,
The penny has dropped at last, i should imagine that most people towing a BT over 19ft with a F250 would be in the same boat, not sure what the numbers are with the F250 as i always thought that ford had an arrangment that allowed the upgrade, it was the reason we went with the GMC, ours has a GVM of 4450 and a tow capacity of 5443 making the total 9893, with a fith wheel it is 6695.
The big problem is that everyone has just followed the "lone ranger" and not checked for themselves.Did you get hold of the engineer that we used i think his name was John but as i said Doug would remember.Hope you sort it out, by the way the GMC is a great truck well deserving of a Baroma
AnswerID: 573230
Follow Up By: Luvntravln - Saturday, Oct 27, 2007 at 17:54
Hi,
I contacted Carrolls and spoke to Jim the plant manager. Wasn't able to get to Doug as he gave me the name of Alan. Spoke to Alan and he indicated that it shouldn 't be a problem to increase both the GVM and the GCM; charge $1,760.
If you have a way of reaching Doug and finding John - great!
If GCM is the total of your GVM + your towing capacity then I assume that the GCM of the F250 would be 4219 + 4500 = 8719. If I can simply increase my GVM to 4500 so that the GCM by that definition is 9000 I can definitely live with those numbers.
I simply am trying to find official clarification of the numbers; I have written to Ford Australia - waiting for response.
Jay
FollowupID: 848750
Follow Up By: adams44 - Sunday, Oct 28, 2007 at 01:06
Jay i gave you a bum steer the guy's name was "Alan" and i think "Marberg" he wanted the truck for 2 days in the end he did it in the 1 days but did 500k's so ask him how far he needs to take the truck 500 seem a little bit to much testing for me , also cost 1760.00 so must be the same guy, did extensive breaking test laden down with computers etc, said we could go to over 6Tonne if we wanted but we only wanted the 4495 which he did.
Doug i think said he was going on a trip so he could be away i also spoke to Jim on the phone what our GMC says is "Max Tow on Ball 12000lbs which is around 5443 Tonnne what hitch will you go with on the new van.
FollowupID: 848751
Follow Up By: Luvntravln - Sunday, Oct 28, 2007 at 04:46
Bingo!
Yes it is Alan Marberg and he sounded very positive.
It is very interesting because Paul has a spec sheet that indicates the GCM is 7369, and my mate has a spec sheet showing 9016!
I wrote to Ford; see what happens.
I am going to ask Alan to give the truck a 4500 GVM and give it a 9000 GCM based upon 4500 + 4500 tow capacity.
My hitch is actually rated at 5500 - I am using the 6000 ring with the pintle from Vehicle Components.
Thanks for remembering!!
Cheers, Jay
FollowupID: 848752
Reply By: Paul and Barb - Saturday, Oct 27, 2007 at 18:47
Jay,
I kept the original Ford specification sheet,here are the details on the weights for the Super Cab
GVM 4219kg
Kerb weight 3146kg
Payload 1073kg
Towing capacity 3500kg. (Now 4500kg)
GCM 7369kg
Front axle 2241kg
Rear axle 2760kg
Paul.
AnswerID: 573231
Reply By: Tellem Bugrem - Tuesday, Oct 30, 2007 at 02:38
G'day Jay,
Yep I read Steve Gibbs' abusive response on this subject on HIS SITE.
Does he have a moderator to ban him from making personal attacks?
Regardless of Steve and Bushtracker, I thought you were buying a Baroma, and selling Big Red. What are you towing the Baroma with?. What will it's GTM be? and what is the towing capacity and ball load limit on your tow vehicle?
Just as well Jackie is slim.........and, I suppose the pair of you save some weight in the wardrobe loading!!!
Good luck with your new rig, safe travels, and hope we'll meet up on the road somewhere.
regards............Rob
AnswerID: 573232
Follow Up By: Luvntravln - Tuesday, Oct 30, 2007 at 03:57
Hi Rob,
No I am keeping Big Red to two my luxury Boroma!
Right now I am in discussions with Ford over the fact that the GCM for the 2004 F250 is 7369 and the GCM for the 2005 F250 is 9016.
It seems that although the upgraded the hitch from 3500 to 4500 they did not increase the GCM!
Will keep everyone advised on this site; I have no intention of having anything to do with "his" site after the way I was treated when all I did was try to impart some information about Carroll's.
Cheers, Jay
FollowupID: 848753
Reply By: Black Cobra - Tuesday, Oct 30, 2007 at 08:17
Jay,
Will be interested also in your findings as fully loaded my dual cab F250 was 4500kg some 200kg over GVM but would not take long to come down with fuel used and water etc.
BT was 4000kg so all up 8500kg. Have upgraded suspension and pintle ring hitch.
Stewart
AnswerID: 573233
Follow Up By: Luvntravln - Tuesday, Oct 30, 2007 at 08:33
Stewart, what year is your F250.
This is the email I sent to Ford in response to their "confidential" email giving me the specifications for the 2004 SuperCab - :
Vehicle Weight (kg)
Kerb 3146
GVM 4219
GCM 7369
Hi,
I am sorry to be pursuing this further however the numbers are significant for all of the 2004 owners with upgraded 4500kg hitch receivers.
From 2004 to 2005, other than the fact that the tow capacity was increased from 3500 to 4500 - which I believe should then be added to the GCM since I have a Ford 4500 hitch receiver, were any other changes made to the F250 from 2004 to 2005.
My friend has a 2005 F250, he has the 2005 spec sheet which shows for the SuperCab a GCM of 9071. What occurred from 2004 to 2005 to result in an increase of 1702kg which includes the 1000 tow capacity increase?
A 7369 GCM that does not take into account the fact that the tow capacity was legally increased from 3500 to 4500 makes no sense because when you add together the GVM of 4219 and a tow capacity of 4500 that equals 8719.
The 2005 GCM of 9071 takes all of that into account.
There is no plate on the f250 that indicates GCM; it is only in the spec brochure.
What was done about the GCM for the 2004 F250s that paid for the legal 4500 hitch receiver upgrade?
This subject is very important as I tow a GVM 4499 caravan based upon reliance on the 4500 upgraded hitch receiver; however, if I am legally limited to 7369 that leaves me with a payload of 2869 which is less than the kerb weight.
The plate on the vehicle says that the maximum front axel load is 2241 and the rear axel is 2817 which totals 5058. That substantially exceeds the GVM.
If you are going to tell me that the 7369 is binding, then I would respond that the 4500 upgrade was no upgrade at all because the difference between the kerb weight and the GCM is only 4223 and that doesn't take into account having a driver!
Perhaps this needs to be discussed with the Ford engineers. At the very least my GCM should be 8719, and I would suggest that since the axel capacity is 5058, the GVM should be 4500 so that a light rigid truck license is not required.
Thank you, I will be happy to call and discuss this further.
Jay Gould
FollowupID: 848754
Follow Up By: Black Cobra - Tuesday, Oct 30, 2007 at 08:54
Jay,
It is a 2004 but a dual cab and the following weights are what I obtained if I remember was from the Ford web site specification sheet.
I wish I had printed one out now but surely Ford would have some records of these specifications.
Weights/Capacities
GVM 4200kg
Kerb Weight 3198kg
Payload 1002kg
GCM includes braked trailer 9071kg
Conventional Towing Capacity 4500kg
Front Axle Load(max) 2241kg
Rear Axle Load(max) 2760kg
So going by these we sould have a 9071kg GCM thats why I have not bothered with obtaining an engineers certificate.
Stewart
FollowupID: 848755
Reply By: Luvntravln - Tuesday, Nov 13, 2007 at 16:18
After Much Ado About Nothing (I went up the Chain of Command until I spoke with someone senior enough to stop worrying about square pegs in square holes) I believe I will shortly be receiving a letter from Ford Customer Relations in Melbourne confirming that the GCM for the 2004 7.3l SuperCab is 9071kg.
Yes!!!!!!!!!!!!!!!!!!!!!
Jay
AnswerID: 573234
Follow Up By: Black Cobra - Wednesday, Nov 14, 2007 at 08:50
Jay,
Sent email to Ford to send me a specification sheet, of which they did but the GCM was listed as 7369.
Can you let me know the procedure and contacts that you went through so I can do the same.
Stewart
FollowupID: 848756
Follow Up By: Kingy - Thursday, Nov 15, 2007 at 09:13
Well done Jay. I'll be very keen to find out the procedure as well...
Peter
FollowupID: 848757
Reply By: Luvntravln - Saturday, Nov 17, 2007 at 04:33
Hi, here is the letter I just received from Ford. I don't think anyone else needs to do anything. Cut and past into notepad and just keep a copy of this letter with your owners' documents. This came to me as an email attachment; I am also supposed to receive a letter on Ford stationary. If it really looks more official I will scan and copy here since nonfinancial members can't post docs. If you want a copy of the letter you can send me an email so I will have the address and I will reply with an attachment (no virus!).
Cheers and Merry Xmas, Jay
15 November, 2007
Mr Jay Gould
53 Glenferrie Rd
MALVERN VIC 3144
Dear Mr Gould
Re: 2004 Ford RN F250 (4X4) XLT Super Cab – VIN 9BFJX21F64B097025.
Ref: 498938
We refer to your recent contact with Ford Motor Company of Australia Ltd (“Ford Australia”), regarding your 2004 Ford F250, registration number WA TGINTL.
As requested, here are the towing capacities and GCM data for the Ford RN F250 and F350 vehicles.
Maximum Towing Capacities
Model 5th Wheel towing capacity (Braked) (kg) Conventional towing capacity (kg) (Braked with Levelling kit) Gross Combination Mass (GCM) (kg)
F-250 4x2 XLT Super Cab 5.41 Petrol P/U 4082 3500 7369
F-250 4x2 XLT Crew Cab 5.41 Petrol P/U 3946 3500 7369
F-250 4x4 XL Single Cab 7.31 DIT C/Cab 6033 4500 9071
F-250 4x4 XL Super Cab 7.31 DIT C/Cab 5443 4500 9071
F-250 4x4 XLT Super Cab 7.31 DIT P/U 5443 4500 9071
F-250 4x4 XLT Crew Cab 7.31 DIT P/U 4717 4500 9071
F-350 4x2 XL Single Cab 7.31 DIT C/Cab DRW* 6078 4500 9071
F-350 4x2 XLT Single Cab 7.31 DIT C/Cab 6214 4500 9071
F-350 4x2 XLT Super Cab 7.31 DIT C/Cab DRW* 5942 4500 9071
F-350 4x2 XLT Crew Cab 7.31 DIT C/Cab 5942 4500 9071
F-350 4x2 XLT Crew Cab 7.31 DIT C/Cab DRW* 5806 4500 9071
F-350 4x4 XL Super Cab 7.31 DIT C/Cab DRW* 5625 4500 9071
* DRW designates that the vehicle is equipped with Dual Rear Wheels.
We hope this clarifies the situation. We trust that you will enjoy many happy and safe years of Ford motoring.
Yours sincerely
Shannon Baker
Customer Service Representative
Ford Customer Relationship Centre
AnswerID: 573235
Follow Up By: NIK `N` OFF - Saturday, Nov 17, 2007 at 04:49
Thank you Jay for doing the leg work and passing the info on. I have made a copy as you suggested.
FollowupID: 848758
Follow Up By: Black Cobra - Saturday, Nov 17, 2007 at 10:05
Ditto, Thanks Jay
FollowupID: 848759
