GVM Upgrade
Submitted: Tuesday, Nov 27, 2007 at 11:28
ThreadID: 124232 Views:17758 Replies:23 FollowUps:17
Can anyone tell me the procedure and cost for upgrading the GVM of a vehicle, particularly a F250 and what is involved.
Who carries out such upgrade and what is required for it to be approved, ie upgraded suspension etc etc.
Also does anyone know of anyone in the west that does this.
Thanks to any help.
Stewart
Reply By: NIK `N` OFF - Wednesday, Nov 28, 2007 at 06:32
Stewart apprently there is someone around Malaga who does GVM upgrades but i don't have any other info than that. I have a mate who is looking into it also If i find out, i'll let you know.
AnswerID: 573508
Reply By: adams44 - Wednesday, Nov 28, 2007 at 15:53
Would cost around $1700.00 plus what needs to be done to the truck that is in Queensland, you would be better off doing the truck first, Springs, shocks, brakes if needed, tyres & wheels, and the chassis also the hand brake then hold your hat and send it to an engineer. Ours went through without any trouble however it is a GMC not F250 you might contact Lunintavel as he was getting his big red done not sure how he ended up, sure is great to run legal.
AnswerID: 573509
Reply By: Eric & Gail - Wednesday, Nov 28, 2007 at 18:41
I have recently had my 1999 US built F250's GVM upraded to the GVM of a F350 4,485 KG, The engineer I used was from Brisbane, don't have his name with me now but can supply it for anyone in this area. I had to supply spec sheets fom the US showing that the F250 and F350 are exactly the same vehicle other than the springs which are double tempered to handle the extra payload, and as I had already installed Firestone airbags all round which have a carrying capacity of 3,500KG and had an extra spring fitted to the rear spring pack, the Automotive Engineer was prepared to give me the upgrade with Compliance plate. I would presume that you guys with the Brazilian built trucks shoud be able to do something similar through the Ford dealers you bought from, good luck
Eric
AnswerID: 573510
Reply By: Wardy - Thursday, Nov 29, 2007 at 01:36
Stuart,
I am in the same situation & made a post (4096) trying source the same info. I have since spoken to F trucks australia Qld ( 0738231098 ) who tell me they can be engineerd up to just under 6000kg , his name was Rob.
On going through 4WD Monthly i found another rig that had upgraded to 5100 through TJM in Qld as well. I will check with TJM in perth to see what they reckon.
Regards John
AnswerID: 573511
Follow Up By: NIK `N` OFF - Thursday, Nov 29, 2007 at 03:46
A thought that F Trucks WA may do or would know who does.
FollowupID: 848899
Follow Up By: Black Cobra - Friday, Nov 30, 2007 at 06:34
Mick,
Would not go to him unless I had to. Thanks John let me know your results with TJM in Perth.
Stewart
FollowupID: 848900
Follow Up By: NIK `N` OFF - Friday, Nov 30, 2007 at 07:34
Malaga Springs & Suspension Centre U1/ 6 Oxleigh Drv Malaga 6090
(08) 9248 1130 was the mob i was told about.
FollowupID: 848901
Reply By: Wardy - Friday, Nov 30, 2007 at 20:08
Stuart,
Spoke with Colin from TJM Perth (0893312788) & he has been onto Qld & will get back to me Mon or Tue.F Trucks WA was a waste of time talking to him yesterday. Looks like things are happening, will let you no results from TJM to compare with Malaga.
Regards John
AnswerID: 573512
Reply By: Wardy - Saturday, Dec 01, 2007 at 08:51
Stuart,
TJM called back & it is a big job aparently & they cannot get it engineer approved at the present time & advised me to ring Licensing. Had no luck there. Rang Malaga Springs & spoke to Dean, they can increase the GVM to 4495kg with supplied engineered plate at a cost of $5800.00 drive in / drive out. Its a 4 day turn around & all suspension front & back including shocks is replaced & roughly gives a 100mm lift. Firestone air bags can also be installed in the rear , bringing the total cost up to $6860.00, but the bags have no input to the GVM increase, only give you extra load carrying capacity if you want it. Thats about where it stands at present. Dean also said to go to a higher GVM , it is another thing , brakes etc & cost prohibitive & they don't do it.
Regards John
AnswerID: 573513
Follow Up By: NIK `N` OFF - Saturday, Dec 01, 2007 at 23:28
Wardy should that GVM be 4495 or 4995 as my friend was quoted, all other figures & prices are the same as he was quoted also,
My friend wrote me last week;
"they can do a GVM upgrade which will increase the GVM to 4995KG - this increases the payload from 1073 to 1349Kg"
I am not concerned about any of it, in our situation the current truck is plenty for the amount we tow and carry but it is certainly confusing reading all the different information, especially after reading Jay's letter he received from Ford stating
Conventional towing capacity (Braked with Levelling kit) (kg) 4500
Gross Combination Mass (GCM) (kg) 9071
FollowupID: 848902
Reply By: Wardy - Sunday, Dec 02, 2007 at 01:20
Mick,
The figure of 4495kg's is what he told me & they keep it at that figure ( 5kg's under ) so the Ford dosn't step up into the Light truck catagory ( over 4500kg's ) & a Light truck or MR license is not required to drive it. I would have liked that little bit more myself, but as Dean said , thats as high as they go . I will ring again on Mon to cofirm , so as there is no confusion amongs't the rank's.
Regards Wardy
AnswerID: 573514
Reply By: Wardy - Sunday, Dec 02, 2007 at 01:25
Mick ,
Just got through to Dean & he confirmed the figure of 4495kg's max.
Enjoy the rest of the weekend.
Regards Wardy
AnswerID: 573515
Follow Up By: NIK `N` OFF - Sunday, Dec 02, 2007 at 02:40
Ok, thanks Wardy, appears to be a typo error on my friends part then, i have copied and sent him what has been written here.
Good luck with it all.
FollowupID: 848903
Reply By: Black Cobra - Monday, Dec 03, 2007 at 09:57
Wardy,
Thanks for all the info and I might give them a ring and see what it would cost just for the engineers certificate and plate as I had the suspension just done. At that cost I don't think I would worry about it as I weighed in at 4500kg fully loaded and once a bit of fuel, water, food etc was used it would come in at legal weight of the 4200kg.
Stewart
AnswerID: 573516
Reply By: Luvntravln - Tuesday, Dec 04, 2007 at 02:02
Speaking of Jay's letter, I just received the original from Ford!!
We are picking up our new home on Friday; I will scan next week and send to Stewart via email and he can post in documents for owners and nonowners. As a nonfinancial member I can't post any documents.
Jay
AnswerID: 573517
Follow Up By: NIK `N` OFF - Tuesday, Dec 04, 2007 at 07:46
Hi Jay
you have got a friend of mine pulling his hair out LOL whats left of it.
He is a Boroma owner and is going down the same path trying to find a tow vehicle that is legal for his 2900kg tare Boroma. He has been conversing with Ford customer service & Coffey Ford in Victoria and getting different figures quoted to him than you have received. I would be interested in your thoughts on what he has written. Oh i did suggest he contact you personally and he may do that.
It's lengthy but below is what he wrote me,
Quote
Hi Mick, sorry mate -the 4995 is a typo error - it should be as Stuart says 4495kg.
The calculation for payload increase with 4495kg is correct in my email at 1349kg -an increase of 276 kg. Not a lot for $6860 but it would do me and it is legal.
However ----- when I spoke to Dean at Malaga, he said 50mm lift was as far as he could go - not 100mm as Stuart was told.
He said anything over 50mm could be an issue for getting it signed off by his engineer. I accepted that as I do know that legislation exists for doing swerve tests on vehicles with over 50mm lift - an expensive exercise.
I also accepted 50mm lift provided I could have air bags to raise the vehicle higher when I needed it - Dean said fine but air bags do not rate in the GVM upgrade equation - it is the leaf spring change that is recognised as the method of increasing GVM.
There is another problem though - the GCM. It doesn't change no matter what is done to the GVM.
I have been quoted by Ford Customer Relation Centre [a person named Kara] and by Andrew of Coffey Ford that the GCM for a 4x4 F250 super cab [around 2003-4 era] is 7369kg - if this is correct then with a GVM upgrade to 4495kg I could only tow 2874kg.
Without the upgrade and a payload of 1073kg on a tare weight of 3146kg giving a GVM of 4219kg I can still only tow 3150kg with a super cab F250.
Whichever way I go, I cannot legally tow a 3500kg caravan with a super cab F250 according to Ford. scary?
One thing is worth thinking about -these figures Ford quoted to Jay maybe for the imported models not those made specially for the Australian market - these had downgraded diffs, brakes and axles to keep the vehicle within the realms of a person with a car licence - the fully imported models have higher GVMs / GCMs etc and need a B class licence - this I got from a guy at the transport dept [ dept of Planning and Infrastructure] - he said Ford made a huge mistake in downgrading the F250s for the Australian market.
This makes sense when considering the amount of misleading information Ford is putting out - there must be thousands of people driving Australian spec F250s illegally and maybe Ford doesn't want to admit the problem.
I am getting cold feet about F250s - maybe the 350 is the answer? but the dual wheels when offroad make me hesitant and the asking prices are around 80K for a basic vehicle.
Or maybe the fully imported F250? - again VERY high asking prices - suggesting some people already know there could be some sort of conspiracy with the Aussie models?
End quote
FollowupID: 848904
Follow Up By: Black Cobra - Tuesday, Dec 04, 2007 at 09:03
Thanks for that Jay will be away until the 18th so will post in documents when I get back.
Stewart
FollowupID: 848905
Reply By: Deleted User - Tuesday, Dec 04, 2007 at 05:02
G'day all,
This is what I have done. Found a Engineer, supplied him with the max. axle load front 2241kg, rear 2760kg....total 5001kg, load rating per tyre 1400kg total...5600kg. Tare 3146kg, existing GVM 4219kg. I asked for an upgrade of the GVM to 4495kg. He checked the vehicle (2005 F250 Supercab 4X4 Diesel) mentioned that the load ratings are well within the limit, wrote out a certificate and blue plate, collected $300 and it was done. Took the certificate to the DOT and had the rego paper changed.
This is all it takes to upgrade the GVM to 4495kg. If you want more... its a whole different ball game.
Adrian
AnswerID: 573518
Reply By: Deleted User - Tuesday, Dec 04, 2007 at 05:10
Back again ..... forgot to mention that I live on the Gold Coast and Wardy....I think paying $5800 for the same end result (GVM 4495kg) is a bit over the top????
Adrian
AnswerID: 573519
Reply By: Luvntravln - Tuesday, Dec 04, 2007 at 08:07
Hi and hard to know where to start -
THE NUMBERS GAME - what can I say - I have the letter in hand signed by Shannon Baker from the Customer Relationship Centre, it is on Ford Letterhead, applies to the 2004 Ford RN F250 (4x4) SuperCab, specifically my F250 referenced by VIN number, and contains a chart that indicates that for the SuperCab the GCM is 9071 and a tow capacity of 4500.
Anyone who says it is still 7369 has not done their homework because Ford increased the GCM when they increase the tow capacity from 3500 to 4500. For the record Shannon kept telling me 7369 until I went over his head up the food chain.
If you increase the GVM from 4219 to 4495 and you have a van weighing 4495 for a total of 8990 you are home in so far as GCM is concerned
BUT
GVM will kill you because it includes the ball weight.
My fully loaded F250 will come in under the 4495 when I find someone in Victoria to increase the GVM (does anyone know someone that will do the increasse); however, there is no way when you add a ball weight 400++ that you are going to be within your GVM.
The horns of the dilema is that if you increase over 4500 you have to get a light truck license and no one without a lt lic can drive your vehicle legally.
The bottom line is that the only vehicle in Australia made for the Australian market that is close to legal for the big heavy vans is an F250. This does not include the imported vehicles.
Am I going to increase the GVM to 5000? Haven't decided and havent' found anyone to do any increase in Victoria.
Cheers, Jay
AnswerID: 573520
Follow Up By: NIK `N` OFF - Wednesday, Dec 05, 2007 at 07:27
It appears that the crucial info is RM and RN models, more info sent me.
Hi Mick,
What Jay says is correct but only for RN series F250s - at least according to FMCo. The RN series was released in August 2003. The RM series was released in August 2001 and was superceded by the RN in August 2003.
The RM series according to "Reece" at Customer Relations Centre at Ford has a GCM of 7369KG and a GVM of 4219Kg subtracting the two gives the towing capacity = 3150Kg
The RN 4x4 series according to Jays letter from Ford has a GCM of 9071Kg and a towing capacity of 4500kg -this calculates to a GVM of 4571Kg
Ford were unable to find the tare weight figure [ but I think it is 3146Kg] of the vehicle I was questioning at the time - a 2003 4x4 F250 super cab - I provided the Vin number as 9BFJX21F538083244 - which they claimed was a late RM series with the above GCM of 7369Kg + GVM of 4219Kg so no way can it tow a 3500Kg caravan - only a maximum of 3150Kg.
When people increase the GVM of the vehicle - it increases the payload but not the GCM -that remains the same unless huge changes are made i.e dual rear wheels, larger brakes etc - that as one BOG member says is a whole different ball game.
end quote/
I own a Oct 04, Ins papers & rego state its a RN so a GCM of 9071,
FollowupID: 848906
Reply By: Luvntravln - Wednesday, Dec 05, 2007 at 08:27
"The RN 4x4 series according to Jays letter from Ford has a GCM of 9071Kg and a towing capacity of 4500kg -this calculates to a GVM of 4571Kg".
Don't you wish that was the facts!
I have been waiting for the letter from Ford to attack the GVM of 4219; however I think what is missing from your calculation Mick is the ball weight!
Only time will tell - now we attack GVM!!
I believe we are only going to get Ford to increase the GVM - if at all - by 100kg as they have indicated an increase of ball weight from 350 to 450.
That will only take us all to 4319 - still way under reality for the fully loaded F250s.
You still have to make the decision if you want to be required to have a LT license!
Think about it: if I write to Ford and get them to agree to Mick's figures, the moment I receive a letter from the with a GVM of 4571 we are all driving illegally!!
OK wise guys, what do you say to that potential problem before I write to Ford?
Cheers, Jay
AnswerID: 573521
Follow Up By: NIK `N` OFF - Wednesday, Dec 05, 2007 at 23:49
"Think about it: if I write to Ford and get them to agree to Mick's figures, the moment I receive a letter from the with a GVM of 4571 we are all driving illegally!!"
Oooh my head hurts, all these calculations ......LOL
Jay just a slight correction, they were not my figures, they are figures written and sent to me by a prospective F250 owner trying to get a grip on all this before he [IF] takes the plunge.
I 'think' my friend calculated the ball weight at 350kg included in that figure of 4571
Personally, i dont have a issue with the weight, no canopy or heavy load, i just like the Effy for it's wheel base and grunt.
FollowupID: 848907
Follow Up By: Black Cobra - Friday, Dec 07, 2007 at 04:15
Jay not a problem have my MC road train licence already, bring it on can tow 3 BT's if I find the right vehicle.
Stewart
FollowupID: 848908
Follow Up By: Titans - Saturday, Dec 08, 2007 at 07:09
I dont have a problem with it - I have a HR licence
Lola
FollowupID: 848909
Reply By: Deleted User - Wednesday, Dec 05, 2007 at 19:30
G'day all,
this is the way I see it. I had my GVM (legally) increased to 4495kg which gives me an extra payload of 276kg or in total 1349kgs. The pay load is what the F250 can carry on its back which also includes ball weight. If you are already loaded up carrying your maximum pay load and want to hook up your caravan you will be over the GVM but not GCM limit, so you have to start taking things of the back of your truck to compensate for your ball weight. If you can't do that then you are up for a dual axle conversion and a light truck license. I don't think there is any other way. Just my opinion.....happy to be corrected.....
Adrian
AnswerID: 573522
Follow Up By: Kingy - Thursday, Dec 06, 2007 at 01:52
Adrian
Is the standard wellback tray weight included in the tare or the payload?
FollowupID: 848910
Reply By: Deleted User - Thursday, Dec 06, 2007 at 03:26
Kingy.....the 3146kgs tare or kerb weight is stated on the rego paper and is the weight including the styleside trayback for a 2005 F250 supercab XLT 4X4 7.3 Diesel pick up as it comes off the showroomfloor.
Adrian
AnswerID: 573523
Follow Up By: NIK `N` OFF - Thursday, Dec 06, 2007 at 05:26
Just to confuse things even more LOL would you believe the tare written on my rego papers for my 04 F250 crew cab well body state = Tare : 2834
FollowupID: 848911
Reply By: Andy1 - Thursday, Dec 06, 2007 at 16:03
There appears to be a strange anamoly in this thread.
If there is this huge difference between the GCM on the RN and RM what is the difference between the trucks? GCM is, all other things being equal, is essentially an issue relating to structural strength & braking capacity. I have never heard it suggested that there was any significant structural difference between the two models, brakes are the same. The alternator is smaller but this hardly has an impact on GCM.
In other words it defies engineering logic that one has a GVM of 7,369kg & the other 9,071kg. Even Ford must see this! If the 9,071 is correct it must, based on engineering criteria, apply to both models unless there is some pretty significant, yet to be disclosed, difference between the two.
Andy
AnswerID: 573524
Follow Up By: Andy1 - Thursday, Dec 06, 2007 at 16:05
GCM not GVM in last para.
FollowupID: 848912
Follow Up By: Luvntravln - Thursday, Dec 06, 2007 at 17:05
Andy, I believe the difference, in part, relates to the fact that the RM models are 3500 tow capacity and the RN models are 4500 tow capacity. My RN was 7369 until I kiced some ass up the food chain at Ford and insisted on the GCM upgrade because of the increased tow capacity.
No one has explained why it didn't simply increase from 7360 to 8369 and instead was increased to 9071.
Cheers, Jay
FollowupID: 848913
Reply By: Deleted User - Thursday, Dec 06, 2007 at 18:11
Back again.......
Nick n off......the tare on your rego paper is that of a Single Cab/Cab Chassis XL (2821kg)......so the dealer who first registered the truck must have made a mistake (suprised????)
Andy......unfortunately you can't expect engineering logic from Ford Oz in regard of the F250, for them they are only a sideline and not worth the hassle.
Adrian
AnswerID: 573525
Reply By: Willie - Thursday, Dec 06, 2007 at 19:50
For anyone with a little Landcruiser 100 , I am just going through the upgrade business myself in Sydney .
I put my car and 16' BT over the weighbridge at Barnes Caravans and the result was not good :
Toyota 100 Series TD auto 3.18 tonnes
Bushtracker 16 ft 2.58 tonnes
Tow ball weight 0.18 tonnes
The Cruiser is "heavily" optioned with steel bar and Kaymar rear bar and internal drawers . And add to that another 127 kg of fuel , clothing , food , detecting gear and an extra spare on the alloy rack .
The current gvm for the car is 3260 kg . Thge negineer says he can re-rate it to 3798 kg .
This is the mail I received from the engineer last week .
"Hi Mike,
This poor Cruiser is working hard! The mods you have carried out are right on target. You have had good advice.
The suspension, air spring helpers, shocks, etc, sound fine.
Tyre rating? On the sidewall of the tyre it will have a load rating. (1250kg for example-this times 4 wheels = 5000kg. Then the RTA Engineers take off at least 20% safety factor. 5000kg-1000kg = 4000kg combined load rating)
Your new GVM for this vehicle will be approximately 3798kg. If your tyres are the same as the example above your tyres just make the grade!
Approximate cost, without tyre upgrade, is $2,760 plus GST. This includes RTA Engineers costs, Blue Slip and new rating plate.
Any questions please give me a call or email.
Regards, John Burke.
Specialised Vehicles [john@specialisedvehicles.com.au] "
Cheers ,
Willie .
AnswerID: 573526
Follow Up By: TroopyTracker - Friday, Dec 07, 2007 at 07:43
Willie,
That is one hell of an upgrade! People have been getting utes and troopys up to 3500kgs for years but you're talking nearly 300kgs extra on top of that! I can see this would be good advice for many who travel outback as most would be uninsured/liable in case of an accident in their current state.
The thing to keep in mind here though is that the GVM increase does not raise the all important GCM (probably around the 6700kgs in your case????)
The price quoted does sound exy?? Is any chassis modifications etc made?? Surely they do more than just look at it? Sure you'd have to have adequate suspension....but most that are already overloaded do anyway :-) Maybe they upgrade the brakes also?
Good luck, just don't forget the overal allowed weight of your rig (van and car) is not increased when you upgrade only the GVM....
Matt
FollowupID: 848914
Follow Up By: Willie - Friday, Dec 07, 2007 at 21:05
Matt ,
At the moment , I have no problems with GCM as my 16 ft BT only weighs 2,580 KG ( half loaded up ).
I have asked the engineer if the max axle weights , max tow ball weight and GCM will also be re-rated . I will let you know what he says .
Willie .
FollowupID: 848915
Reply By: Kingy - Friday, Dec 07, 2007 at 05:15
This is a good read, especially the bit about legally upgrading to 5195.5Kg GVM with just a suspension upgrade which I already have.
link text
AnswerID: 573527
Reply By: Luvntravln - Saturday, Dec 08, 2007 at 16:39
Seems lots doing the GVM increase in QLD - has anyone done or does anyone know of an engineer that will do an increase in VIC?
Jay
AnswerID: 573528
Reply By: Luvntravln - Tuesday, Dec 11, 2007 at 07:34
The original Ford letter has been sent to Stewart and Andy in .pdf format. One of them will post in the documents section.
Now, onto dealing with GVM.
Cheers, Jay
AnswerID: 573529
Reply By: Black Cobra - Thursday, Dec 20, 2007 at 09:40
Jays letter from Ford Australia has been posted in File Swap FYI, thanks for that Jay.
Stewart
AnswerID: 573530
