Webasto during storage
Submitted: Tuesday, Dec 11, 2007 at 18:24
ThreadID: 124268 Views:4554 Replies:8 FollowUps:1
I have read previously about the risk of fungal and other contaminants developing in diesel when unused for a long period of time. Turist (I think) has recommended using Fuel Doctor additive which helps prevent problems developing in stale fuel.
If the van is being left in storage for some time (eg 6-9 months), my question is:
a) Is it better to empty the diesel and burn off any residual fuel which increases the risk of air in the lines aiding the growth of fungi and other stuff, as there is still going to be fuel clinging to the lines and parts? or
b) Just add the Fuel Doctor and not worry about it?
Reply By: SMICK - Wednesday, Dec 12, 2007 at 04:04
I have been reliably told to put a litre of kero in the tank, fill it with diesel, then run Webasto for about 1/2 hr. Apparently the Webasto will run on almost anything that will burn. I have done this, only trouble is kero is bloody expensive
AnswerID: 573646
Reply By: The Murray Marauders - Wednesday, Dec 12, 2007 at 20:20
Ditto to kero in tank, dont worry about emptying tank, waste of time. Roger at Webasto will talk to you online.
John Duncan
AnswerID: 573647
Reply By: Willie - Friday, Dec 14, 2007 at 20:06
How long does it take before the bacteria cause damage to the diesel ( Sydney temps ) ?
I do not have room in my nearly full 4 lt diesel tank for a litre of kero - what quantity of that Fuel Dr do you need to add to a 4 litre tank ?
Is Fuel Dr hard to find in auto shops ?
Thanks ,
Willie .
AnswerID: 573648
Follow Up By: Turist - Friday, Dec 14, 2007 at 22:01
If your diesel tank is full to the top you have little chance of fuel algae forming.
Fuel algae just loves half full tanks, a bit of humid air inside the tank promotes it.
There are a number of proprietary product to prevent fuel algae available from auto parts shops.
FollowupID: 848955
Reply By: Flipp'n Lorry - Saturday, Dec 15, 2007 at 01:48
You would only need about 25ml of Fuel Doctor in a Webasto tank - it comes in a 250ml bottle for about $20. You can use the rest in your tow vehice, so it won't be wasted.
See Site Link
AnswerID: 573649
Reply By: ChrisVal7 - Saturday, Dec 15, 2007 at 23:47
Phil and Lorraine,
thanks for raising this question; I am now better informed should we leave the van in storage for a while, rather than running around in it permanently as now.
My question relates to how often one needs to run the Webasto heater, to keep the system in order. At present we are in the heat (Alice Springs, after 3 months in or around Darwin) and won't be in cold weather for a few months. I guess one should run the heater every now and again...so what are the implications for storage?
Chris
AnswerID: 573650
Reply By: Flipp'n Lorry - Sunday, Dec 16, 2007 at 03:14
I don't know the answer to that question I am afraid - if you click on the sponsor link for Webasto and mail Roger, I am sure he will advise. Let us know the answer, there would be a few of us interested in that.
AnswerID: 573651
Reply By: ChrisVal7 - Monday, Dec 24, 2007 at 22:18
I have been in touch with Roger (of Webasto national office) and asked him this question. He says there is no need to worry about running the heater while either in storage or during the hotter months. Apparently the need to run the unit regularly is more about de-coking it, as if the heater is run too often for short periods of time, it can gunk up - so it needs a good long run of an hour or so every now and then.
But he does suggest putting some gladwrap over the intake pipe, and securing it with a rubber band, to stop critters and creepy crawlies getting up there and creating a nest. Sounds like very good advice.
Chris
AnswerID: 573652
Reply By: Eric & Gail - Tuesday, Dec 25, 2007 at 01:31
I use chemtech deisel additive in the F250, is this a simmilar product to the fuel doctor,
Eric
AnswerID: 573653
