12volt diesel submersible pump for Jerry cans
Submitted: Thursday, May 29, 2008 at 07:35
ThreadID: 124758 Views:5151 Replies:5 FollowUps:0
Does anyone know or can recommend a 12 volt submersible diesel pump currently sold in Australia that I can put down the throat of a Jerry can and pump into the tug? If so, can you provide make/model and selling outlet?
Reply By: Mobi Condo - Thursday, May 29, 2008 at 08:59
Have you considered the Tanami style set up? Fits to the neck, mouth or what ever of the fuel can, sealed off of course with a car tyre valve and stem in order to pressurise the fuel container. A metal tube also penetrates the sealed cap and extends to the bottom of the fuel can. The fuel delivery tube fits to the metal tube. A "few" pumps of air into the can pressurises the vessel and pushes out the fuel! Not sure where one buys such, plenty have been made though!
Cheers - Ian & Sally
AnswerID: 575210
Reply By: Silver and Tinks - Thursday, May 29, 2008 at 22:34
I have seen jerry can pumps for sale at Repco
Hope this helps
Scott
AnswerID: 575211
Reply By: Wadefarers - Friday, May 30, 2008 at 04:36
Have you considered the jiggle thingie. Just a length of plastic tubing with the brass bit with a marble in it. Costs about $6 - $10 and it really easy to use. Bought mine in market stalls. Just keep the jerry can above the outlet. Insert into jerry can, insert the flow end into tank, jiggle the marble end and voila, easy as pie. I carry two, one diesel and one petrol, and wouldn't be without them.
Jeff
AnswerID: 575212
Reply By: Neil and Linda - Friday, May 30, 2008 at 06:43
I am also looking at getting a submersible pump that will fit inside a Gerry can. I have been told Whale pumps are the go but haven't sourced one yet. Have a look at their web site. Site Link .When I get a chance I will call into a boating shop to have a better look. If there is anyone using the whale pumps for diesel I would like to know how good they are and where they purchased them from.
cheers Neil
AnswerID: 575213
Reply By: Keith & Joan - Sunday, Jun 01, 2008 at 19:01
QUOTE FROM WHITWORTHS MARINE AND LEISURE, 2007 CATALOGUE. P53
www.whitworths.com.au
UTILITY SUBMERSIBLE PUMP.
This 12 volt 18 litre/min pump can be used for most general pumping applications, eg hosing down, bilge pump, shower pump, or with the end strainer removed, as a permanent in line fixture for water systems. SUITABLE FOR DIESEL, fresh and salt water. Takes 1/2 inch tube, and is supplied with four metres electric lead fitted with clips for attacment to battery. Maximum pressure 1kg/cm2.
Size 166mm x 38mm (looks like a round tube) Cat no 67215.
RRP $163.00 OUR PRICE $129.00
Hope this helps, Kind regards, Keith & Joan.
AnswerID: 575214
