F250 rear airbags
Submitted: Thursday, May 07, 2009 at 22:54
125637
4624
Motherhen & Rooster
What pressure do you have in yours when towing?
| Motherhen
Reply By: NIK `N` OFF - Friday, May 08, 2009 at 02:32
If i am using the WDBars the bags are 35 - 40psi
If not using the Bars then 50 - 55psi
what ever works for you and the weight in the truck & draw bar.
577738
Reply By: Paul and Barb - Friday, May 08, 2009 at 02:32
Hi Mum,
I only recently installed mine and find that I only need 25lb pressure with the van on. (Van ball weight is around 300kg.)
Paul.
577739
Reply By: Silver and Tinks - Friday, May 08, 2009 at 05:01
Hi Motherhen
We run 60 to 70 psi but we have a canopy, loader, boat, outboard ,big generator, fridge and other gear in the truck and little bulldog and 3 jerry cans on the front of the van.
The pressure you run is all relative the amount of gear you carry and your tow ball weight if you are light you need less pressure.
remember the airbags reduce load on the springs and the bounce on the shocks thus reducing wear on those components.
Best wishes.
Scott and Jacky
577740
Follow Up By: Sooty & Sue - Wednesday, May 13, 2009 at 07:10
Hey Motherhen
On the tarmac upto 50psi with WDH bars. On dirt roads down to 20psi. If you have too much pressure in on dirt roads you'll end up causing a lot of vibration and damage/
Sooty
851229
