Flourescent replacement globes - where do I buy them please ?
Submitted: Thursday, Jun 18, 2009 at 01:39
ThreadID: 125768 Views:4922 Replies:7 FollowUps:11
Howdy Boggers,
One of my small flouro lights has failed. The double parallel tubes are joined together and possibly have a built in starter. The model number is Phillips
PL-S11W/84C.
Is there a mail order supplier for these ? Is there a stronger wattage I can safely use in these little roof lamps ? I gather these are 11 watts.
Thanks a lot,
Willie.
PS I just drove from Sydney to Leinster and back without seeing another BT. We are a select few !
Reply By: Turist - Thursday, Jun 18, 2009 at 02:04
Bunnings Willie.
But only buy the Phillips one, for some peculiar reason the other brands will not work.
AnswerID: 578041
Follow Up By: Willie - Thursday, Jun 18, 2009 at 02:20
Bob, can I use more than an 11 watt model ?
W
FollowupID: 851393
Follow Up By: Turist - Thursday, Jun 18, 2009 at 02:31
No.
FollowupID: 851394
Follow Up By: Willie - Thursday, Jun 18, 2009 at 03:10
Bob, what do you mean "On"
Tks for info
FollowupID: 851395
Reply By: Tracks n About - Thursday, Jun 18, 2009 at 03:59
G'day Willie & Bob,
I'd grab 2 if I were you Willie. We've had our BT since June 2004 and have gone through 5 tubes. BUT we are told that they last forever !! Have always had trouble finding the same tube,so thanks Bob for the imfo. I've always gone to electrical shops,thinking it would be a specialty sort of item. Will definently go to Bunnings and get a supply before we head off to Lake Eyre in 3 weeks.
Lawrie
AnswerID: 578042
Follow Up By: Willie - Thursday, Jun 18, 2009 at 06:44
Thanks Lawrie, I will get four.
Willie
FollowupID: 851396
Follow Up By: Doug and Kim - Thursday, Jun 18, 2009 at 21:07
Lawrie
From what we have heard talking to others that have come down south from Lake Eyre be prepared to pay $250 plus each for a flight over the lake from either maree or william creek to see the lake and water in flows have stopped.
Cheers doug n kim
FollowupID: 851397
Reply By: Mobi Condo - Thursday, Jun 18, 2009 at 04:28
Howdy there - us too thanks for the thread and the inof -
Hi Ho, Hi Ho
its off to Bunnings we go
- tomorrow!
Cheers - Ian & Sally
AnswerID: 578043
Reply By: Frank Aus - Thursday, Jun 18, 2009 at 05:48
Hi Willie
Halls Creek for me in 2 weeks time and Meekatharra next year with some luck, thats if they let me have more long service, if not it will be Clermont for a couple of weeks and maybe Rubyvale for some stones instead. But on the Subject of lights the 11 watt relates to power consumption and not light output, believe it or not but the light output from the 11watt is much betteron light output than the 13 watt lights, and like all fluros, they have a life and while they continue to glow their light output is down, when you need a torch to see if they are on , it past due to be changed, if they take a long time to fire up, change them as well. I have bought mine from a Electrical wholesaler and being an electrician always where i go, only get bleep off when buying at "trade prices" find cheaper at Bunnings. But must admit never tried the 11 watt at Bunnings before. so worth a try.
AnswerID: 578044
Follow Up By: Willie - Thursday, Jun 18, 2009 at 06:50
G'day Frank,
I tried the Sydney wholesaler Turks today - no luck, so I will go to Bunnings tomorrow.
Thanks for that info . I might replace them all, as they are very dim.
I have some friends doing a detecting tour at Halls Creek this week. I was there last year and some big bits were found. ( but not alas by me ! ).Hope you make it up there.
Willie.
FollowupID: 851398
Reply By: The Hob - Friday, Jun 19, 2009 at 01:26
Read Willie's post with interest so went and had look at ours.
They are Phillips PL-S 11W/840/4P
ie Compact flouro 11W (the 840 is a brightness rating) and 4 pins. Need to release the 4 grub screws to remove bulb.
But I can't find any replacement ones.
I went to 3 Bunnings stores - only have 2 pin
I went to 6 lighting and electrical places - none have 4 pin but a couple offered to order them in.
I went to a caravan parts place and they had one but it is a energy saver so dull light.
Went to BCF - they had them but only for 7W
They seem to be scarce and very specialist in application.
I'll keep looking and when I find them I will have to get several for the future.
The 2 pin 11W one at Bunnings was $9.00 the 4pin one at a caravan parts place was $21
If anyone finds a source on north side of Brisbane I would be interested to know.
AnswerID: 578045
Follow Up By: Willie - Friday, Jun 19, 2009 at 02:57
Alan,
I went down to a huge Bunnings at Lidcombe in Western Sydney today. They had the 11w two pin, but no Phillips only Crompton.
I purchased three and will see how they perform, before I buy more.
Willie.
FollowupID: 851399
Follow Up By: Pixellator - Friday, Jun 19, 2009 at 03:27
Springers Low Voltage Specialists have them in stock (confirmed to me on Monday). The Philips PL-S 11W / 840/ 4P is from my Resolux 101 lights... not sure if they suit the older fluoros suppied previously by Bushtracker. I believe that they only fit the Resolux lights now. We supplied the Resolux 101 for our van in March 2005, on Jay Gould's recommendation. BT obviously thought they are OK!
Springers have two branches:
704 Gympie Road Lawnton 07 3889 8898 (northside)
1029 Manly Road Tingalpa 07 3890 8898 (south east)
www.springers.com.au
sales@springers.com.au
i'm going to the tingalpa store tomorrow.
Best wishes
BobH
FollowupID: 851400
Follow Up By: The Hob - Friday, Jun 19, 2009 at 06:02
Thanks BobH I will get to Springers very soon.
I have the 4 pin bulb (van is Nov 2008) so maybe the lights have been upgraded.
Willie must have 2 pin. (Heaps of Phillips 2 pin at Bunnings up here)
Thanks again
FollowupID: 851401
Follow Up By: Pixellator - Friday, Jun 19, 2009 at 22:51
Springers price $15.90 for Philips PLS 840/4P. Plenty in stock at Springers Tingalpa. I warned them to expect lots of BT owners!
FollowupID: 851402
Follow Up By: The Hob - Sunday, Jun 21, 2009 at 03:02
Thanks Bob
Went to Springers at Lawnton on the northside and they had several in stock.
As I bought a few of them they said they would order more in.
Thanks again
FollowupID: 851403
Reply By: Motherhen & Rooster - Sunday, Jun 21, 2009 at 23:29
Hi Willie
Some of ours failed, and we too found it hard to get the right wattage, shape and size to fit. The original brand ones were no longer stocked as they were too expensive. I don't recall where we purchased them from, as it was a few years ago and we have changed most over to LED lights. I did an internet search to find them. Only one yet to go, and that needs doing as it sometimes works, sometimes doesn't and sometimes flicks.
AnswerID: 578046
Reply By: Willie - Monday, Jun 22, 2009 at 03:03
If I was going to replace the entire light fitting with an LED one, what would you suggest ( brand / model / availabale at) ?
Thanks,
Willie.
AnswerID: 578047
