F250 airconditioning condensation water
Submitted: Thursday, Jul 02, 2009 at 00:49
125822
3481
Eric & Gail
Hi fellow F truck owners, I have condensate water dripping from the bottom of the evaporator box which is behind the glove box, onto the floor into the cabin. I have checked the drain hose for blockage and all clear, any ideas. My truck is a 1999 US built, converted so position of evaporator may be different to the Brazilian trucks.
Eric
Reply By: NIK `N` OFF - Thursday, Jul 02, 2009 at 08:29
Haven't had the problem with our F250 Eric, but i did encounter a similar problem in the past with 2 other vehicle's, one was a blocked drain hose [which you have checked] and other the condensor or evaporator [not sure which] had ice forming over it.
578194
Follow Up By: Eric & Gail - Thursday, Jul 02, 2009 at 18:48
Thanks Mick, may have to resort to an Airconditioning specialist, just thought someone out there may have had the problem with their F250.
Eric
851463
Reply By: Flipp'n Lorry - Friday, Jul 03, 2009 at 03:48
I had this problem in Landcruiser - the evaporative box was in two parts, and seal between them was disintegrated.
578195
Reply By: Eric & Gail - Friday, Jul 03, 2009 at 04:54
Hi Phil,
Thanks for that tip, I will check that out, not sure if mine is in two parts.
Eric
578196
