Megapulse on AGM batteries
Submitted: Friday, Sep 18, 2009 at 08:58
126061
10154
7
Spirit Gypsys
Has anyone had any experience with a Megapulse on the AGM batteries.
I've heard a lot of good stuff on megapulse but mostly on ordinary lead-acids.
I've just emailed megapulse but then they're selling them aren't they.
Reply By: Doug and Kim - Saturday, Sep 19, 2009 at 07:53
We have a megapulse in the van and 4wd checking our batteries for the past 24 months and it works like a dream.
Only problem we had was it stopped working on the birdsville track (rattled inside), emailed the company and they sent me a new one in 48hrs and i return mailed the old one ,couldnt be happier with the product and it is swapped between 4wd and van at 6month intervals.
578921
Reply By: Ski Clubbers - Sunday, Sep 20, 2009 at 21:12
What is a Megapulse?? Please explain!
Ta
578922
Follow Up By: Noosa Fox - Monday, Sep 21, 2009 at 00:49
It is an electronic device that you put on your battery and it is designed to cause the internal battery plates to vibrate at a very fast rate, and in so doing so that causes that sulphate that has attached to the plates to dislodge. A battery without sulphate on the plates is a healthy battery, and will last and operate better and longer.
We have had one in the F250 for years but I think it is faulty now as the lights do not always work.
It is also supposed to help restore old batteries.
Have a look at their web site
http://www.megapulse.com.au/
851804
Reply By: Ski Clubbers - Monday, Sep 21, 2009 at 20:59
Thanks Brian
We are supposed to learn something new each day & for us this is it.
Graeme & Jan
578923
Reply By: Spirit Gypsys - Tuesday, Sep 22, 2009 at 08:35
Thanks for the responses
I've done a bit more research and yes the megapulse does appear to work just as well on AGM's as well as ordinary lead-acids.
My email to megapulse was very seriously to the positive
so I reckon I'll spend the $100 odd as it doesn't seem too out of line when forking out around a grand for new batteries if it will give me a few more years out of them.
578924
Reply By: Silver Fox - Tuesday, Sep 22, 2009 at 22:35
I have just read my 'C-Tek' manual which indicates it can "de-sulphate batteries". during its cycle. cheers
578925
Reply By: Mumbles & Mur - Wednesday, Sep 23, 2009 at 05:56
Is one of these units required per battery?
We have 7, 4 van, 3 vehicle.
Cheers.
578926
Reply By: Spirit Gypsys - Saturday, Sep 26, 2009 at 06:21
I received a reply from megapulse tech. and they reccomend one unit is necessary for the van batteries (3 or 4) and one for the vehicle, (3 in my case with a 70w solar panel on the 2 aux. batts.as well as after full charging from the cranking batt.)
They reccomend the connection being from the positive on the first battery to the negative on the last battery.
Fairly simple really.
578927
Follow Up By: Noosa Fox - Saturday, Sep 26, 2009 at 06:34
As the batteries are connected in Parallel it wouldn't matter where they are connected as all the positives and all the negatives are linked by heavy cable.
If it was a series connection then their recommendation would make sense but not for our parallel type connects.
851805
