Camec windows - can latches be replaced?
Submitted: Tuesday, Oct 27, 2009 at 04:17
126142
4061
Motherhen & Rooster
Our black slide and lock latches seemed to have reached 'use by' date, and a couple of the locks have broken off. I can still slide manually, but it opens in transit.
| Motherhen
Reply By: Bobrovin - Tuesday, Oct 27, 2009 at 06:03
Hi MH
You can buy the latches from Camec and probably from most caravan spare part suppliers.
To change them you have to drill the rivet out that holds them on and re rivet the new ones on. From memory you need a rivet gun with a narrow nose to pull up the rivets as they are in a countersunk hole
579149
Follow Up By: Bobrovin - Tuesday, Oct 27, 2009 at 17:58
MH
Its been a few years since we had to do this and memory faded.
You dont need the pointy tip for the riveter as the countersink is there to stop you pulling the rivet up tight. The catch moves on the rivet and it needs to be loose enough to allow movement
851930
Reply By: Turist - Tuesday, Oct 27, 2009 at 20:11
Hi Mum.
No need to replace the catches, the new ones can get loose very quickly.
Only have to replace if part actually broken off, if the problem is just that they vibrate open I have put a fix in the Owners
Forum.
579150
Follow Up By: Motherhen & Rooster - Friday, Oct 30, 2009 at 04:33
Thanks Bob, I will look it up. The turning handle bit has ripped out at the rivet. They came loose first, then dropped off. Easy to push the sliding bit to shut the window, but after a while they move, and on a particularly windy day, the wind kept lifting the window open a bit so it could blow all the dust into the van.
Mh
| Motherhen
851931
