Genny Location
Submitted: Saturday, Jul 10, 2010 at 20:16
126698
3771
Luvntravln
We are considering an extended drawbar and installing a 3kva Honda remote start on the drawbar under an aluminum cover with mesh grills for exhaust and air intake.
I have looked at the installation inside the storage locker with a bracket and it seems to me that you eliminate the ability to use that side for other storage, you open the van to dust and dirt entering from that side unless the cavity is sealed, depending upon the weather you are either taking the genny out or quickly putting it away.
We currently have a 3kva remote start and once we setup camp somewhere, e.g., the Gympie muster, all we do in the morning is push a button and instant 240 and the battery charger is in operation.
Those that have a genny on a bracket in the storage compartment, what if any problems have you encountered; would you do it again?
Thanks,
Reply By: Len & Judith - Thursday, Jul 15, 2010 at 06:18
we have a drawbar mounted geny, with a open base and a removable sealed cover,i remove cover when useing,we have been through 900mm water with no problems, hope this helps,len..
580795
Follow Up By: Luvntravln - Thursday, Jul 15, 2010 at 07:06
It do help, Mate. What size genny; can you post a couple of images or send them to luvntravln@gmail.com? Thanks muchly, Jay
852702
Reply By: Len & Judith - Thursday, Aug 12, 2010 at 06:50
we are at our mine until late Sept. i can do photos when we get home if that is not to late .len
580796
Follow Up By: Luvntravln - Saturday, Aug 14, 2010 at 23:11
wow, your own mine!! Per chance Lightening Ridge? We met "she" of a BT couple when we were in LR several years ago.
September would be fine!!
Good huntin'
Jay
852703
