shower door and shower wall ledge leak
Submitted: Tuesday, Jul 27, 2010 at 09:14
126758
4517
7
PUGO CLAN
HI
does anyone else's bathroom door drive them mad - Latch STICKING so becomes very difficult to open and shut. We have been on the road six months now and this has been a continual problem. does anyone know what product we can put on the black latch / clip mechanism which will work and allow for easy operation but not make it fall open all the time when travelling?
Also have just noticed that there seems to be water getting in under the aluminium ledge under our shower door as there is water dribbing down the outside of the wall and it is water marked and it is obviously getting into the wall itself under the ledge. Has anyone else had this problem?
Rachael
Reply By: Deleted User - Tuesday, Jul 27, 2010 at 12:12
Y E S
580915
Reply By: Uncle Dodgy - Tuesday, Jul 27, 2010 at 22:38
Yes.
The Leak
Damage repaired by the factory under our insurance.
Have since installed a shower screen inside the shower to ensure no recurrence. Plastic film curtain type screen mounted on a telescopic curtain rod that I think we bought from Bunnings.
The catch
Try a light spray of silicone spray on the catch, particularly with the springloaded catch pushed in.
580916
Reply By: Oldfella - Wednesday, Jul 28, 2010 at 00:27
G'day
Not had any water leak problems but I solved the latch problem by lightly rubbing a cake of soap on it,works for me.
Chers
Graham
580917
Reply By: Sundy & Cyclone - Wednesday, Jul 28, 2010 at 05:04
A year or 2 back we had a door catch problem similar to what you're talking about, we tried various methods including a new catch but turned out to be the
re-positioning of the lower hinge that solved the problem. Discovered that the door was very slightly "off square" to the door frame, only moved the lower hinge about 3mm to solve the problem ???.
Cheers Tony
580918
Reply By: NIK `N` OFF - Thursday, Jul 29, 2010 at 01:29
We have had the two small springs break in our catch, i substitued some foam pushed in the hole and that worked well for 18 months, when we were nearby the Stegbar company at Maroochydore last we obtained some new springs and the catch complete, after installing i found the door to be very hard to open & shut, my fix then was to reduce the size of the button / catch with a small sharp knife to get it to close & stay closed.
Also on the shower door topic, within 1st few weeks of ownership our shower door initially came off the bottom hinge due to the screws not protruding far enough into the lower frame, longer stainless steel screws & job done, still good 3 years later.
580919
Reply By: Dunrootin Lodge - Friday, Aug 13, 2010 at 03:27
Hi, we had the same problem with the shower door being hard to close. I worked out it was the frame around the door panel that was coming away from the plastic panel. Mine actually came right out. It is a hard job to push the frame/seal back onto the panel but with persiverance it can be done, using flat screwdrivers (not philips). Next, buy a good quality ocky strap and stretch it around the door when travelling, it should hold the frame to the panel and solve your problem.
Can't answer your leaking problem, we don't have that. However, wiping down the shower cubicle after every shower with an absorbent cloth gets rid of the moisture.
Also empty the shower head after your shower as water left in the head/hose tends to run out when travelling. Ian
580920
Reply By: Flipp'n Lorry - Saturday, Aug 14, 2010 at 22:23
We had same issue as Sundy & Cyclone. Check if screen door is square in frame.
If you need relocate bottom hinge fitting, remove door by flexing it out in the middle and this will release lower pin from hinge mount. You need to flex door a lot, but it won't break.
580921
