Long Range Fuel Tanks
Submitted: Sunday, Aug 01, 2010 at 18:05
126769
9764
14
7
Lets went
Hi all just looking at getting a larger diesel fuel tank in my 2010 200 GXL wagon,
can I get some views on this please which would be the better ones to look at.
Reply By: The Hob - Sunday, Aug 01, 2010 at 18:34
My 200 plus 19ft BT is close to weight limits. (with 4 water tanks full)
More fuel could blow the limits!!!!!!
580944
Reply By: Lets went - Sunday, Aug 01, 2010 at 20:53
Hi Alan
I should be right as the 200 has the 3800kg up grade.
580945
Reply By: Willie - Sunday, Aug 01, 2010 at 21:02
G'day John,
I got ARB to fit the 170 litre tank and had a Kaymar spare wheel set-up (mounted on the rear bumper).
I had the same set-up on my 100 TD and it gives me about 280 litres. The only downside is the fuel guage, which you have to learn to read a different way. It does not start to move until you have used a thrid of a tank and at three quarters, you have about 100 litres left etc etc.
As for weight, I had an ARB GVA upgrade before it was registered.
It is great for me, as I go bush, leave my van out there and detect for a fortnight without having to go into town for fuel. Also it's mighty handy for avoiding fuel rip-offs like you find on the Nullabor and from Alice to Adelaide.
Willie.
580946
Reply By: Gone Bush - Monday, Aug 02, 2010 at 01:26
Hullo John & Helen,
I just got back from 18,000kms Perth to SA, NSW, QLD, NT and back. I have the factory sub tank in my 200 series giving me 138 litres. One purpose in this trip was to see if a long range tank was needed. I carried 2 jerry cans on the drawbar and only needed to fill them twice on the whole trip. Half way through the day I would transfer the contents into the vehicle with a Tanami Pump (very easy using an air compressor, you don't even need to lift the cans out of their holders) and all the rest of the trip I didn't need the extra litres.
So I've decided not to bother with a long range tank and the inconvenience (mainly for my wife) of a swing out wheel carrier.
Hope this helps.
PS: it also seems bad economics to me to spend a few grand on a tank/wheel carrier just to cope with one or two stretches around the country where a bit of extra range is needed.
PS2: I spent it on a Chip and a Beaudesert exhaust instead !!
580947
Reply By: Mumbles & Mur - Monday, Aug 02, 2010 at 04:57
Gone Bush.
Hi Stephen,
Could you please tell me a bit more about the Tanami pump.
Possibly been covered before in other posts but I either missed it or the memory doesn't stretch that far.
Ken
580948
Follow Up By: Gone Bush - Monday, Aug 02, 2010 at 05:12
Hullo Ken,
here is their website:
http://www.tanamipump.com.au/
It sits on the jerry can with an identical cap to the original jerry. You then connect your compressor to it while putting a hose from it into your vehicle. Turn the compressor on and the air pressure pumps the fuel out into your vehicle.
It's so easy.
852778
Follow Up By: Gone Bush - Monday, Aug 02, 2010 at 05:14
And I see on their website they now have different models for different types of fuel containers.
Cool.
852780
Follow Up By: Gone Bush - Monday, Aug 02, 2010 at 05:18
Just to clarify my first Follow Up above: you only put it on when you want to pump out the fuel.
It's not as tight a fitting as the original cap so it doesn't over pressurise the can.
Works really well.
852781
Reply By: B & T with BT - Monday, Aug 02, 2010 at 05:49
just saw this post, we have the willow diesel jerry cans, so looked up the webpage as per Stephens post and ordered the Birdsville for our particular diesel jerry cans, $99 plus $13 for postage, done.
B&T
580949
Follow Up By: Gone Bush - Monday, Aug 02, 2010 at 06:04
Well done B&T.
Just to explain further how easy this is, I made an Anderson Plug adapter for my Air Compressor.
I sit the Compressor on the tailgate of the Cruiser, plug the Anderson adapter lead into the Anderson plug on the van's drawbar to power the compressor.
Connect the compressor's air hose to the Tanami Pump.
Put the fuel hose into the fuel inlet on the Cruiser.
Turn on the Compressor.
Easy.
852782
Follow Up By: B & T with BT - Monday, Aug 02, 2010 at 06:42
Thanks Stephen, that is just what we were thinking
B&T
852783
Reply By: Mumbles & Mur - Monday, Aug 02, 2010 at 18:12
Hi Stephen,
Thanks for the info, it just went to the top of my "MUST HAVE" shopping list.
Ken
580950
Reply By: Leigh & Mita - Friday, Aug 06, 2010 at 19:44
The Tanami Pump sounds like a winner and is now on my "Must Have List" also.
Beats the heck out of lift jerry cans
Leigh and Mita
580951
Reply By: B & T with BT - Friday, Aug 06, 2010 at 21:23
Ours arrived in the mail today, the boss is very happy, but we are still going to get the 70litre Loneranger auxillary tank fitted, that should come next week. Got a price from Mannell Motors $1950 fitted.
B&T
580952
Reply By: SMICK - Saturday, Aug 07, 2010 at 02:17
I took our patrol to Mannel motors to have the front wheel bearings checked and serviced, if needed. They did a vehicle service and a bearing check by wobbling the wheels. NOT VERY happy as I had only serviced the patrol 1000K before hand.
580953
Reply By: B & T with BT - Saturday, Aug 07, 2010 at 02:35
Really how long ago was that, they did are GVM upgrade, black widow boxes and the radio. We did chat them about the sloppy way they did the wiring on the radio but other than that they were OK, Who else in Sydney would others suggest you go to for the auxillary tank. Long ranger themselves recommended Nick Mannell,
B&T
580954
Reply By: Lets went - Saturday, Aug 07, 2010 at 15:48
Thanks to all who have replied I have now got some good idea's.
580955
Reply By: Tellem Bugrem - Saturday, Aug 07, 2010 at 19:44
Hello John,Helen et al
Out of Town 4WD at Barnsley (Newcastle) can install three different auxilliary tanks on the 200 series. They have a 70 litre tank that fits above the spare wheel
and this can be fitted to vehicles that have been supplied with one or two tanks. So if your model has the main tank + sub tank (about 138 litres) you can ad the 70 litre tank to give you 208 litres, without having the spare wheel removed.
The other two installations they do are a 90 litre and a massive 180 litre, both of which require relocating the spare wheel to hang out the back door.
You can find more on their website:-
Out of Town 4WD
www.thelongranger.com.au
or you can ring them at (02) 4953 3288
In our 9 years of travel throughout Australia we have carried 2 jerry cans on the A frame, but have actually used them on 5 occasions. However, If I was going to go to the LC200, I would have the 70 litre tank fitted.
Cheers......Rob
580956
Follow Up By: Gone Bush - Saturday, Aug 07, 2010 at 20:24
Rob, the 70 litre tank replaces the 45 litre factory sub-tank. It doesn't sit alongside it. This was copied from the Longranger brochure on the 70 litre tank:
Fitment of the LongRanger
Auxiliary tank provides the user with a boost
in driving range thanks to a 55% increase
over the standard 45L sub tank to give a new
total of 163L.
852784
Reply By: Tellem Bugrem - Sunday, Aug 08, 2010 at 00:26
Hello Stephen,
When I wrote the post, I had just got off the phone to Out of Town 4WD and they definitely said that the 70 litre tank is in addition to the two tanks already there.
So, if anyone is contemplating an installation, they might likle to ring them.
Cheers......Rob.
580957
