Waterproof tray for washing Machine
Submitted: Friday, Aug 13, 2010 at 02:52
ThreadID: 126797 Views:3781 Replies:3 FollowUps:2
I am having trouble getting a Waterproof tray to put under the washing machine, which is in a cupboard at the rear of my BT. The waste hose split open last trip and caused some water dammage to the base/front panel of the cupboards. Iv'e fixed the leak but want to put a tray under the washer to catch any future leaks. Any suggestions on where to source a tray? sizes 400mmW X 450mmL X 75mmH. Without paying too much. Also the fridge light no longer works and it's not the globe. I seem to remember someone mentioning a wiring "by-pass" at the rear of the fridge. If someone could explain that to me it would be much appreciated.
Ian.
Reply By: GoinThere - Friday, Aug 13, 2010 at 03:57
Hi Ian just a suggestion - what about a "Black Plastic" heavy duty tub frm the local hardware - don't weigh much and completely watertight.
Terry
AnswerID: 580986
Reply By: Deleted User - Friday, Aug 13, 2010 at 17:14
You can get one made to fit from a metal fab place., aluminium or stainless steel
AnswerID: 580987
Follow Up By:- Monday, Aug 16, 2010 at 01:22
The fridge is 12/24v and the cabinet lamp is 12v so they use a 12v voltage regulator IC to drop the voltage from 24 to 12 when using 24v.
Water spashes around where the IC is and the terminals corrode and it goes fizz futt and no more cabinet light. The fix is to rewire it for 12v only.
FollowupID: 852791
Reply By: Grumblebum & Dragon - Saturday, Aug 14, 2010 at 00:05
Re the fridge light.... probably a loose connection on the control box at the back of the fridge. or a poor connection around the mirco switch inside the fridge. You may be just able to get your hand into the rear of the fridge via the lower vent if you have small hands.
If not undo all the small screws surrounding the fridge inside the van. Remove the big retaining screw at the back of the fridge, unload most of the fridge contents to reduce weight and the slide the fridge forwars to give you more access space at the rear. Check all the connections - they are only the spade type and often can get loose on corrugations.
Cheers John
AnswerID: 580988
Follow Up By: Dunrootin Lodge - Wednesday, Aug 18, 2010 at 21:51
Thanks for all the advice, Tried Grumble's way and must have touched the right wire connection as the fridge light now works. Thanks to Scooter for making me a SS tray for my washing machine. Problem solvered. Ian.
FollowupID: 852792
