Removing flyscreens from Four Seasons hatch
Submitted: Thursday, Aug 26, 2010 at 18:57
126835
6957
6
Flipp'n Lorry
Is there a link/thread on how to do this - have searched and can't locate anything?
Reply By: The Boondockers - Thursday, Aug 26, 2010 at 20:04
There was an instruction sheet on Camec's site which I downloaded some time ago, however it only shows you how to replace a broken flap. It does have a cross section drawing though. I will try and post it in Tips.
I suggest you send Australite a email:
For enquiries, please contact thasner@australite.com.au or gmatthews@australite.com.au
Rosco
581064
Follow Up By: The Boondockers - Thursday, Aug 26, 2010 at 20:08
I placed the tip under windows. The diagrams did not load.
Rosco
852819
Reply By: Deleted User - Thursday, Aug 26, 2010 at 21:18
We spent a couple of hours cleaning our hatch and flyscreens only last week. Once the hatch was fully open I removed the screens carefully from the top corner lifting and peeling them away from the frame and then lifting them from the bottom as they have a lip arrangement on them on the bottom edge.
Peter and Laraine.
581065
Follow Up By: Umpire83 - Thursday, Aug 26, 2010 at 23:32
That is the way to do it, I found it easier to stand on stool to get head and hands up into the hatch to see what I was doing - turned out to be easy to do.
852820
Reply By: Deleted User - Friday, Aug 27, 2010 at 02:41
This is my trick:-
Obtain a few large bath sheets.
Lay them around randomly below the hatch
Spray the hatch liberally with a chlorine type cleaner.
Fire up the high pressure water blaster and presto good as new with no damage and no dismantling.
trust me it works
581066
Reply By: Grumblebum & Dragon - Saturday, Aug 28, 2010 at 04:05
Are they fairly easy to refit once you have them out?
581067
Follow Up By: Sassy Sam - Sunday, Aug 29, 2010 at 08:36
Fairly easy but sometimes a little fiddly and you need to try a few times. Refit at the bottom first, pushing, with your hand through the hatch, from the outside and checking from the inside that they are firmly over the bottom external bar. Then refit the top. It takes a little pressure and is better to do in the cool of the morning as it can sometimes get a little warm with your head up in the hatch. Patience will see you succeed.
Good luck.
Sheryl
852821
Reply By: The Murray Marauders - Monday, Aug 30, 2010 at 00:17
When replacing them, attach the bottom of the screen first, then the sides and then do the top. Very easy after you have done it the first time.
John D
581068
Reply By: Grumblebum & Dragon - Monday, Aug 30, 2010 at 00:46
Thanks Guys... good info.
John and Jean
581069
