Tow vechicle
Submitted: Monday, Oct 18, 2010 at 05:02
ThreadID: 126954 Views:4944 Replies:6 FollowUps:12
We have a 200 series pulling a 20' BT, due to weight issues we are considering upgrading to a larger vehicle (american)
anyone got any thoughts on type make etc.
Thanks in advance
Reply By: B & T with BT - Monday, Oct 18, 2010 at 06:11
Welcome to the club your not along, there seems to be quite a growing number now. We are considering the new 2011 Silverado with the much larger fuel tank, caravan sway control, engine braking and with the aussie dollar its looking better all the time.
Teresa
AnswerID: 581351
Follow Up By: Noosa Fox - Monday, Oct 18, 2010 at 18:53
Teresa,
The longer wheel base definitely helps with stability but because you mentioned "Caravan Sway Control" I take it that you have sway problems sometimes.
We had a 100 series towing our 21ft van and suffered from sway after we had 2 extra water tanks fitted. This caused our ball weight to be too low and we changed the location of the water tanks and the batteries and that solved the problem.
I measured the ball weight the other day and it was 250kgs and the van is 3500kgs if we fill all the water tanks.
I suggest that if you have sway problems that you check your ball weight, because on our first trip after having the 2 extra water tanks fitted we came to grief.
FollowupID: 852970
Reply By: Gone Bush - Monday, Oct 18, 2010 at 07:49
We have a 200 series and I'm not saying don't change, just joining the conversation.
On a long trip we take out the centre row of seats. They are really heavy and this allows us to replace that weight with personal stuff.
Even so, we play a game that goes along the lines of: how much can we leave at home? How little "stuff" do we need?
In the Cruiser we have a set of rear drawers, 30 litre engel, 2 chairs and a small table. We don't carry a roof top tinny and I can see where that would need a bit more carrying capacity. I know people who do carry them but are completely unaware of the weight stacking up.
I had a look at an imported F350 the other day, brand new. Great in all respects except that the driver's footwell (formerly the passenger footwell) is so small that 3 pedals (handbrake is a foot pedal) and my two feet, would have real trouble fitting in. I don't know how the Silverado fares there.
AnswerID: 581352
Follow Up By: Pixellator - Monday, Oct 18, 2010 at 10:27
Does anybody know what the insurance/legal implications of removal of seats are?
I was told once that one must have the number of seating positions available as stated on the compliance plate or registration certificate or something.
Something else that was raised once was that the centre row of seats contribute towards the vehicle's torsional rigidity. Those centre seats and mounting brackets are certainly a bit of a job to remove, at least in the 100 series.
All seems a bit strange to me, but other views would be interesting.
The weight saving is certainly an appealing factor, also makes it easier to turn down a hitchhiker!.
BobH
BTW Stephen, did you have a birthday party for your BT on 14 October? (!!) LOL :)
FollowupID: 852971
Follow Up By: Motherhen & Rooster - Monday, Oct 18, 2010 at 10:58
Hi Bob
As far as i can ascertain, temporary removal of seats is OK. We took seats out of our Patrol for our trips and put them back on return. We do similar with the seats in the half cab of the F250, taking both on only one side out depending on our needs at the time. Only permanent removal is a modification. If a vehicle needs the seats to hold it rigid i don't want to be in it! :o
FollowupID: 852972
Follow Up By: Gone Bush - Monday, Oct 18, 2010 at 18:28
Removal of seats and compliance issues are a factor in Queensland, if your vehicle is registered in that State, but, apparently, nowhere else.
The seats in my 200 are as heavy as lead compared to those in my previous 80 series. It takes 2 of us to carry the larger one of the 60/40 seats in my GXL.
And yes, Bob. We spent a few days away laste week in the van. Up the new Indian Ocean Drive, across through Dandaragan, Moora, Wongan Hills, Goomalling, Toodyay. Beautiful country and a fitting birthday trip.
FollowupID: 852973
Follow Up By: Pam and Les - Monday, Oct 18, 2010 at 18:54
To give us a bit of extra room in the car for our recent Simpson desert trip I looked at removing the rear seats. Before I do anything to the car/van/trailer I always check with the ACT rego office. They are very helpful and the tech officer told me that the rules also require the removal of the seat belts. They would then issue a new seating compliance plate if I wanted.
FollowupID: 852974
Follow Up By: B & T with BT - Monday, Oct 18, 2010 at 19:03
Stephen, Personally (and this is my personal opinion) in hindsight I think to use these vans for what they are designed for, a 19ft van should be the maximum BTi should recommend behind the likes of the 200 series cruiser otherwise we are all playing the what do we leave behind game or don't fill all the water tanks or only carry two of everything, Whats the point in having them if we can not use them to their full potential. When we were in the so called design process, we told them we wanted a 19ft maybe 20ft as we were concerned about the weight factor and did not want to be towing on the upper limit all the time. Also we would like to be able to put a tool box on the front as we did not want the genny, chainsaw etc in the cargo hold, we told them we wanted 4 water tanks, 4 batteries and 4 solar panels, Ok we may have got carried away with it all, in the excitement but they meaning BTi should have said "hang on a moment you've only got a 200 series, weight is now going to be an issue" but no they said "Oh you can have a 21ft in the rear ensuite design and still weigh the same as the 20 footer and still be OK behind the cruiser and led us to believe that we would still be around 2800 maximum. Our tare plate says 2780, Like others we weighed van completely empty literally stripped it, took out all water plugs so that when we went to weigh bridge it would have shaken most of the water out of the pipes etc (although I still allowed 20ks in there as recommended by Steve Gibbs. Without tool box and associated brackets and yes we even weighed the screws and bolts (54ks) Oh and I allowed another 20ks for TV and associated brackets, backboards etc not to mention 23ks in the hot water system we still came in over 2900, allowing for those extras we are 3ton. The gear in the tool box weighs 86ks, then you fill the fridge and pantry, theres bugger all left, Looks like we go naked. We don't blame BTI the buck stops with us, we made the decision But if I had my time again I would not have gone over 19ft behind the cruiser as I also love my car and have spent, like a lot of others a lot of money setting it up. I WOULD STRONGLY SUGGEST TO ANY NEWCOMERS THINK TWICE BEFORE YOU FALL INTO A FALSE SENSE OF SECURITY THAT 21FT IS OK BEHIND A CRUISER NOT IF YOU WANT TO USE IT TO ITS FULL POTENTIAL. In saying that we love our van and don't want to part with it hence us looking at the Silverado.
I know there will be others who disagree and thats Ok with me this is my opinion only and may mean diddly squat to others, but if it helps others not be in the same position as us (and I know quite a few who are) then it can only be a good thing that I write this. I also realise that this issue is not just confined to BT's I am sure that other so called off roaders would have the same problem.
Stephen I made many queries in regards to layouts etc on both forums and contacted some members personally and we felt we did our homework, I pestered BTi to the point I am sure they were sick of hearing from me but still here we are.
Just my thoughts on the weight situation.
Teresa
FollowupID: 852975
Follow Up By: NIK `N` OFF - Monday, Oct 18, 2010 at 19:27
I agree that 19' is a good size BT, we have one :-)
But even being a 19' doesn't neccesarily make it a light weight, our tare is 2620kg and with a limit of 3500kg we still have to be aware of what we take.
Interestingly i have looked at a few 20' vans lately, and there appears to be very little difference in tare weights to ours.
We have done the opposite to what some owners are doing we used to tow with a F250 and now tow with a VDJ79 series Toyota, no back seats to worry about :-)
I haven't felt any stabilty problems towing, power is ample and we are back enjoying 4WD'n places we wouldn't have taken the larger vehicle.
FollowupID: 852976
Reply By: B & T with BT - Monday, Oct 18, 2010 at 19:19
Sorry Brian I was writing before I saw your answer, yes we are looking into that because our tow ball weight with the tool box on the 500mm ext drawbar was only 180kg. So we put as much in the toolbox as we can and in the cargo hold rather than the van. (before box went on it was only 140kg to 150kg according to Matthew at BTi) Like others most personal stuff goes in the car. We don't have a lot of sway, only every now and then but we don't fill all water tanks only 1 or 2 and never the rear ones. Its more the pitching and the feel that the van has control over the car I don't like. Its not a relaxing ride. But I will mention to hubby about repositioning water tanks.
Teresa
AnswerID: 581353
Reply By: Gone Bush - Monday, Oct 18, 2010 at 21:02
Hullo Teresa,
yes, I can remember you asked a few questions of me during your build. I hope I was some help.
The feeling of the van being in control of the vehicle (I call it the tail wagging the dog) can be caused by a few things you can look at.
Too much weight behind the vans axles. Empty the rear water tanks first.
Wheel alignment. Too much toe out (I think, I'm no expert here) can make the van feel like it's "waddling".
The hitch is too high on the vehicle. Remember I sent you the WDH set up procedures? That may be worth re-visiting.
For interest's sake. Our van is a 20 footer with the rear ensuite. It's Tare, as measured by BT, is 2660kg. I took it over a weighbridge but when I measured the tow hitch weight I still had the WDH bars up and tight so the result is wrong. I need to do that again.
The whole issue is worth looking at before you spend huge dollars on another vehicle.
While it's not much consolation for you, our van tows very smoothly behind our Cruiser.
AnswerID: 581354
Follow Up By: B & T with BT - Monday, Oct 18, 2010 at 22:10
Yes Stephen I do remember and yes you were of help to us particularly with the WDH instructions which we never got from BTi until I emailed them but by then I had a copy from you, Many thanks. We did as per the instructions and changed position and level and it has improved slightly but not enough for our liking. The only water tank I fill now is the drinking water and hubby takes little Honda water pump and we fill from the dams etc where we have been frequenting lately, its either that or caravan parks. I am very careful what and how we pack van. Which brings me back to my original comment. "Why pay all that money to have a van of this calibre if I can not use it for what it is designed for. I think the term I have heard used by a solictor (not mine) was "Not fit for purpose" Sorry if it sounds like i am bemoaning my lot, life could be a lot worse, its just frustrating when you fork out all that money and have a certain expectation only to find your bubble burst really quick.
Teresa
FollowupID: 852977
Follow Up By: Gone Bush - Monday, Oct 18, 2010 at 23:59
Teresa, it would be really interesting for you to find another 200 Series owner, with a BT between 19 and 21 ft and swap vehicles and vans and drivers and see if they feel different.
Why don't you take a quick trip over to WA and we will do that........
FollowupID: 852978
Follow Up By: B & T with BT - Tuesday, Oct 19, 2010 at 03:52
Thanks Stephen for the offer, your just a little too far away. Despite this we had in fact already thought about this as my sister has just picked hers up (21ft) and our good friends Sally and Todd also have a similar layout and they tow with a 200 series GXL. So I think we will try this when next we get together. Indeed I think it will be interesting to see if it is a pecularity of our setup. Also I think we will drop right down to the lowest hole in the 150mm hitch as you did. That is the only thing we have not tried yet.
Teresa
FollowupID: 852979
Reply By: The Hob - Tuesday, Oct 19, 2010 at 01:51
We have a 200 pulling a 19ft van with 4 batteries and 4 tanks and is I believe at or close to legal limits. The 200 pulls it OK and it tracks very well behind us even with 4 tanks full.
We always empty tanks from rear to front so Ball weight is ever increasing. We have an extended drawbar (300mm) and have 3 jerry can rack on the front but rarely has it been used.
AnswerID: 581355
Reply By: Luvntravln - Tuesday, Oct 19, 2010 at 06:54
Frankly, look at the Ford too! I have a 450 on order for delivery in April.
AnswerID: 581356
Follow Up By: Spirit Gypsys - Tuesday, Oct 19, 2010 at 10:19
I'll just poke my nose into this one .
After nearly 6 years full time on the road our 2001 a/m turbo'd Troopy was getting a bit tired. so to do a repower job we had a 6.5 L Cevy V8 diesel (non-turbo)put in by Brunswick motors in WA. while we were working at Busselton.
we had 4.1 diffs put in as well and now it pulls like a tractor. not fast but who goes fast with 3.5 T of BT behind and 3.2 T in the Troopy.
It cost us $20,000 but that was far cheaper than upgrading to a new V8 troopy
It still gets the same 4.5 - 5 kl/L
Yes the van is on the weight limit and thats with only 1 and half tanks of water.
but then we do live in it full time and periodicly have to do a major throw out.
The biggest reason to us for staying with the Toyota is width.
You cannot get a F'y or "yank tank" down Ozzy bush tracks without one set of wheels being out in the stakes--- let alone not fitting between the trees.
I had an F100 once -- I know from experience.
If you don't intend to go bush then ignore this post.
FollowupID: 852980
Follow Up By: Willie - Sunday, Oct 24, 2010 at 05:12
That is a super important point to my mind, especially as people buy BTs to get off the beaten track.
I could never buy one of those big tanks to go detecting in WA. I would spend my whole time replacing staked sidewalls and looking at the scratch marks on the paintwork.
It not only affects where you go when you are towing, but where you can go when you have unhooked the van and want to explore.
Willie.
FollowupID: 852981
