water pump
Submitted: Friday, Dec 03, 2010 at 01:00
127069
4189
schommys
When washing out the Bushtracker shower at home,the water pump ( for the shower) ran for about 5 minutes and then just STOPPED. No noise, no humming, nothing. The pump was very hot to touch, Water was still available in the tank. Has anyone experienced this before and if so what was the problem and solution.
Regards AL.
Reply By: Cargra - Friday, Dec 03, 2010 at 18:05
check the suction filter on the pump for blockages.
graham
581621
Reply By: Uncle Dodgy - Sunday, Dec 05, 2010 at 21:08
There have been several roports of similar occurrences by members of the BOG group and many with detailed descriptions of fixes.
I recommend full (very affordable) membership of the B O G site, and then download a copy of the BOG Bible, and other very useful resource materials that can be located using the
site search facility on both the current and archived records.
Hope this helps
581622
Reply By: schommys - Friday, Dec 10, 2010 at 02:10
The water pump is up and going. Checked for power to all the right points, all good. Took the rear motor cover off to see if the motor span freely ( it was so hot, I thought it may have sieged up) it was free. I was given an old pump this week so I swapped over the pressure switch assy and that fixed the problem.
Regards AL
581623
