Broken hinge on Camec door
Submitted: Wednesday, Dec 15, 2010 at 22:46
ThreadID: 127086 Views:5323 Replies:7 FollowUps:4
The lower hinge on our BT door has broken twice when the door has swung back
onto the frame of the water proof cover.
I am about to install a stainless steel wire from the top of the door to the door frame, fixed with rivets so that if the door swings open the wire will pull it up rather than the leverage on the lower door..
Has anyone else experienced this problem and got a better fix? (other than ensuring that the door doesnt swing back!!)
Seasons greetings to all
Wayne & Sue
Reply By: Noosa Fox - Wednesday, Dec 15, 2010 at 23:44
Wayne,
Lots of vans have had that problem, including ours. After replacing the complete hinge it happened again so the second time I just put rivets through the other section of the hinge, and that was several years ago now without any more problems.
Neil Matthews (BoysToy) from Sydney has had similar problems and he has a pulley arrangement that goes down the inside of wall beside the door so you might like to speak with him. Neil put the BOG Bible together so he may have something in there about what he has done.
While you are doing things with the door, the outside door handle is also a problem and many have had that break off. If you put a piece of metal like a split pin down the gaps on each side and then use some fibreglass bog or araldite to fill in the gap it gives it a lot more strength and doesn't seem to break.
AnswerID: 581659
Follow Up By: Cargra - Thursday, Dec 16, 2010 at 02:32
G'day Wayne & Brian,
Just to add to Brian's suggestion of filling the door handle with bog, I had done that quite a long time ago which solved the problem at that point but my handle has just now broken further in.
I have now completely filled all the cavities in the new handle to make it totally bulletproof.
graham
FollowupID: 853137
Reply By: Silver Fox - Thursday, Dec 16, 2010 at 03:54
I did the small dia wire rope at the top to mine. Pictures on my photos site.
AnswerID: 581660
Follow Up By: Uncle Dodgy - Thursday, Dec 16, 2010 at 04:31
Me too.
I used a suitable length of braided trace wire with electrical terminal ends through which self tapping screws fastened the wire to the top of the van doorway and the top of the van door.
I had to pass the wire twice through the terminal ends before crimping them to get a suitable grip on the wire, and then ran the wire through a length of small diameter clear plastic pipe, to make it more visible so I couldn't garrot myself walking out through the door.
I have seen Neil's set up and think it is superior to mine.
John & Sharyn
FollowupID: 853138
Reply By: Luvntravln - Friday, Dec 17, 2010 at 05:35
For those of us that are all thumbs, images of all discussed would be appreciated.
AnswerID: 581661
Follow Up By: Cargra - Saturday, Dec 18, 2010 at 18:42
Here's a pic of a job half done. Filling the handle with plastic metal only moves the weak point.
I have now completely filled the cavities and waiting for the next weak spot to appear, ha ha!!MPG:19!!MPG:18!
FollowupID: 853139
Reply By: Motherhen & Rooster - Friday, Dec 17, 2010 at 07:41
Image Could Not Be Found
Hi Jay
After one breakage per owner, the door was running out of rivet spots. I can happen so easily in very strong winds - the wind actually blows the door out of your hand and the hinge cracks.
These were version one - made of a very lightweight chain enclosed in clear plastic tubing so it didn't rub against the door. It was so soft, that the ends straighten and it can fall off when slack. A straight cable like others have would be better (so long since we've been away i can't remember what my husband replaced it with).
AnswerID: 581662
Reply By: Luvntravln - Friday, Dec 17, 2010 at 18:36
Thanks MH; some close up images would be appreciated. Cheers,
AnswerID: 581663
Follow Up By: Motherhen & Rooster - Saturday, Dec 18, 2010 at 10:13
Hi Jay, it is just pop rivetted on, and these photos show the door clipped fully open which stretches the chain or cable to the maximum. It is still enough to prevent the damage to the hinge in the wind. Idea copied from another member, who appears to have to attachment on the other side of the door.
What do others have? Any more piccies?
Mh
FollowupID: 853140
Reply By: Boystoy - Friday, Dec 24, 2010 at 05:09
Door Saver
I was inspired by the cable arrangement on Uncle Dodgys van, so I made an improved version.
1) The cable system prevents the door from crashing when the wind gets at it.
2) The retractor mechanism acts as an automatic door closer
3) A simple security stop only allows the door to partially open to keep out nasties.
The system consists of a 1.5mm stainless steel cable which is bolted to the door, and runs over a pulley at the top of the door frame. The end of the cable is attached to a 4mm bungie cord which runs around a pulley at the bottom of the door frame, & then runs up to an attachment at the top of the door frame. This length is necessary to get the necessary stretch.
There is an adjustable sleeve mounted where the cable joins the bungie cord, and this is adjusted to a stop to limit the doors travel.
The security stop has a slot cut in it so that the door cable can be slipped into it to provide a second stop (the security stop.)
In the photos, I have used a single pulley at the top of the door. This needs to have the centre tapered so that the pulley can adjust to the angular swing of the door.
I am planning a further modification using two pulleys mounted on a bracket which will simply mount at the top of the door to make installation easier. I haven’t found the necessary pulleys yet, and when I do, I will document the modification for other Boggers to follow.
In the meantime I hope this helps. This current version has been in service for about 8000km without problems. But it is fiddely to get it to work. Wait for the next version.
!MPG:18!!MPG:19!!MPG:20!!MPG:21!
AnswerID: 581664
Reply By: Uncle Dodgy - Friday, Dec 24, 2010 at 20:39
Luvintravelin;
Sorry something I should have mentioned earlier.
I went away from using chain inside plastic tube, because the chain being light was prone to stretch, and eventualy allow the hinge to be stressed.
I found the cable (braided fishing trace wire) to be better, and fitted it to the top of the door from (when inside looking out) the top left of the doorway to the top left of the door ( the screened door and not the outer door as this allows the outer door to be open with the inner closed).
I spoke at length with Neil while we were at Tepon and I feel that his new modified version will be far superior once he located the bits. What he has now is already better than mine I feel.
I wait for his improved version as I feel that will be the way to go.
John & Sharyn
AnswerID: 581665
