SOLAR PANELS
Submitted: Friday, Dec 31, 2010 at 04:43
127115
7728
MUSKY
MERRY CHRISTMASS EVERYONE, I HAVE 3 X 120 WATT SOLAR PANELS ON OUR VAN,A PROSTAR 15 SOLAR CHARGER CONTROLER,ON A GOOD SUNNY DAY WHAT SORT OF AMPS SHOULD BE REGISTERING ON MY AMPS METER,JUST A ROUGH AVERAGE WOULD BE FINE. THANK YOU MUSKY & MARE.
Reply By: Noosa Fox - Friday, Dec 31, 2010 at 07:05
You should be getting at least 4 amps per panel. With 2 by 120, 1 by 125 and 1 by 130 watt panels we have readings of up to 32amps when the batteries are down a bit and sunlight is good.
BTi always used to say that 3 by 120 watt panels required a 30 amp solar regulator. It is strange to only have a 15 amp regulator.
Also if the panels are Kyocera 120 watt panels manufactured around the 2000 -2002 era, then most of them were faulty and were under a warranty replacement.
Our 3 failed a few years ago and 2 were replaced with 120 watt and when the 3rd went they replaced it with a 130 watt panel.
I would suggest that you throw a blanket over 2 panels and then check the reading that each panel is giving.
581768
Reply By: Motherhen & Rooster - Friday, Dec 31, 2010 at 07:50
Hi Musky and Mare
We too had faulty panels and didn't know it until we got into the tropics where panels don't work so efficiently. We thought 5 amps was maximum from four panels!
When testing, bear in mind that if you batteries are charged, you will only see the amount going in that the batteries need, eg if your fridge is running and drawing 4 amps, the panels will only be able to put 4 amps in.
We had a Prostar 20 - i didn't know there was a Prostar 15. How old is your caravan? We had to change the controller as it was inadequate when we got the four new 130 panels under warranty.
| Motherhen
581769
Follow Up By: MUSKY - Sunday, Jan 02, 2011 at 01:07
thank you for the info,who do i need to speak to for a warrenty claim,& how long is the warrenty on the solar panels last. thank you musky & mare
853184
Follow Up By: Motherhen & Rooster - Sunday, Jan 02, 2011 at 01:46
Hi Musky and Mare
As per my MM, warranty of 25 years.
Kyocera Solar
info@kyocerasolar.com.au
I dealt with George Phani back in 2008 and he was very helpful
Kyocera Solar Pty Ltd
2 Giffnock Avenue.
North Ryde NSW 2113
Ph; 61 2 9888 9999
You will need to provide the Serial numbers from the label on the underside of the panels.
Mh
| Motherhen
853185
