Great Storage Idea
Submitted: Saturday, Oct 15, 2011 at 17:52
ThreadID: 127677 Views:7995 Replies:8 FollowUps:8
I do not take credit: From Alf Horne's van:
Image Could Not Be Found
Reply By: Luvntravln - Saturday, Oct 15, 2011 at 17:53
The wheels are bolted to the doors; I do not know how he keeps his nuts in the boxes on corrugations. He says his nuts do not bounce - hmmmmmmmmmmmm - out of the boxes!
AnswerID: 583231
Reply By: Gone Bush - Sunday, Oct 16, 2011 at 00:16
Great idea.
I have one of those plastic covered wire baskets from Bunnings or Howards Storage on the inside of one of my boot doors.
It holds the rubber gloves I use when emptying the toilet cassette and some soap, sterilising gel and hand cream, all in plastic squeeze bottles.
I'll take a photo and post it.
AnswerID: 583232
Follow Up By: Gone Bush - Sunday, Oct 16, 2011 at 19:15
FollowupID: 853928
Reply By: Luvntravln - Sunday, Oct 16, 2011 at 01:14
Let's keep this going!
Add photos and description.
AnswerID: 583233
Reply By: Tracks n About - Sunday, Oct 16, 2011 at 21:49
Have any of you reinforced the hinges,or do the factory fitted ones handle the extra weight ? If not modified in some way,I'll be interested to see how they handle it. Please keep me updated as I've often thought of doing something like what you've done.
AnswerID: 583234
Follow Up By: Mobi Condo - Sunday, Oct 16, 2011 at 22:03
Yes - we also have kept away from doing this to our dors due to hinge design SWL - so we would alos love to know of any problems or otherwise.
Cheers - Ian & Sally
FollowupID: 853929
Follow Up By: Gone Bush - Sunday, Oct 16, 2011 at 23:57
There's not much weight in my shelf and the only time the hinges would be tested is while moving and I expect the door frame would support it quite well.
FollowupID: 853930
Reply By: Luvntravln - Monday, Oct 17, 2011 at 00:19
I am advised that Alf has had those on his doors for years without any problem.
AnswerID: 583235
Reply By: Luvntravln - Monday, Oct 17, 2011 at 00:49
While we may have a large than average van - 24' - when it is your home you are always looking for ways to create or conserve space. We were due for new cookware; off we went to Myers for their frequent sales. In this case, the sale price was what you could get at a good outlet store: 40% - 50% off of RRP.
We have happily found both pots and pans that do not have handles!
I don't know about your storage; this has resulted in all cookware in one drawer (Jak will probably spread out anyway!)
AnswerID: 583236
Follow Up By: Luvntravln - Monday, Oct 17, 2011 at 00:50
This is the Tefal Ingenio range.
FollowupID: 853931
Follow Up By: Bobrovin - Monday, Oct 17, 2011 at 05:48
We have just ordered the same 2 sets from here.
pots
Also around same price from Victoria's basement
FollowupID: 853932
Follow Up By: Willie - Thursday, Oct 20, 2011 at 19:42
I also stack a saucepan in my frypan.
Both are expensive non stick and I was worried about the coating on the frypan being rubbed off.
I purchased a roll up high density foam sleeping mat (about 1cm thick) from Clarke Rubber and cut it to fit to the bottom and halfway up the walls of the frypan. Then I glued on a ring of the same material to this, so that the saucepan would not move around when placed on top.
It works a treat on the corrugations.
Willie.
FollowupID: 853933
Reply By: Luvntravln - Monday, Oct 17, 2011 at 06:13
That is great; checked the prices and very similar to the sale prices at Myer.
Now, we have one piece left to find and we will be rid of all fixed handles:
AnswerID: 583237
Follow Up By: Luvntravln - Monday, Oct 17, 2011 at 06:21
I wrote to Kitchenware Direct to determine if they can obtain.
FollowupID: 853934
Follow Up By: Luvntravln - Wednesday, Oct 19, 2011 at 18:56
The Blue Ingenio Enamel line has been discontinued!
FollowupID: 853935
Reply By: Ontheroadagain - Wednesday, Oct 19, 2011 at 07:38
Our van is a 2002 vintage. The door hinges have just cracked along the hinge line and have just arranged to have replacement installed. I cannot comment on what the extra weight would have on the hinges but after over 9 years before having to replace the hinges, I could see no problems.
AnswerID: 583238
