Eberspacher Diesel Heater Fault codes
Submitted: Friday, Jan 11, 2013 at 01:02
ThreadID: 128481 Views:3711 Replies:2 FollowUps:1
Does anyone have a full list of the fault codes for the Eberspacher diesel heaters or know where we could obtain one?
The manual only has the 4 most frequent codes and ours are different.
Have contacted Dometic but no luck yet.
Reply By: NIK `N` OFF - Friday, Jan 11, 2013 at 01:40
Have you googled
[full list of the fault codes for the Eberspacher diesel heaters]
and downloaded the pdf file
Eberspächer Troubleshooting and Repair Instructions
File Format: PDF/Adobe Acrobat - Quick View
20 1859 05 00 00. AIRTRONIC L engine-independent air heater for diesel engines. Heater ... This list of contents gives you precise information about the contents of the ..... Fault code table . ....
Possibly something in there that can help
AnswerID: 585241
Follow Up By: 2 excampers - Friday, Jan 11, 2013 at 02:41
Thank you so much.
Have just downloaded it.
It is just what we need.
Many thanks.
Liz & David
FollowupID: 854879
Reply By: 2 excampers - Friday, Jan 11, 2013 at 02:49
Hi again
Just been reading the pdf file and it turns out it is for a different model....ours is the D2 801 series. Wonder if the fault codes are the same?
I wil keep searching.
Liz & David
AnswerID: 585242
