CTS 3110
Submitted: Tuesday, Apr 02, 2013 at 02:16
ThreadID: 128629 Views:3567 Replies:1 FollowUps:0
G'day,
My van has not been used for a couple of months and I have now found that CTS3110 toilet will not flush at the moment. I suspect that the solinoid (the pink one under the switch panel) is the problem. I also had a problem with the taps not flowing and found that the problem with them was that the screens were blocked with calification.
My question is 'how do I remove the solinoid" to either repair or replace it as it is fitted right up at the top of the shroud under the switch panel? Is it held in place by screws or is it just a press (clip in) fit? I can see where it is from the top when I remove the switch panel and from the bottom once the cassette is removed but because the opening is so narrow I cannot actually get in to see how it is fixed in place.
Lou...
Reply By: SMICK - Tuesday, Apr 02, 2013 at 02:43
If you go to the tips section you may find the info there. If there is nothing there go to the BOG Bible, Heaps of info there.
Michael
AnswerID: 585578
