Led light lifespan
Submitted: Friday, Jun 06, 2014 at 17:47
129329
3625
Bobrovin
I would like to know if anyone who has changed to leds has had any problem with them getting dimmer over time. I have put some into a fitting in the house and found that they got very hot and the light fadded out to near nothing over about a month.
Do the ones in the van get very hot?
Reply By: Googs & Zelda - Saturday, Jun 07, 2014 at 00:59
Bobrovin, I've had mine in place (on the B/T) for three years now and still as bright as the day I put them in , and I haven't noticed them getting hot.
I shall give them the touch test next time we go camping.
587472
Reply By: JohnS - Saturday, Jun 07, 2014 at 01:29
LED lights do drop off in performance over time and the operational hours versus lux output data can be looked up if you have enough information. However with the varying quality coming out of China it's a bit of a lucky dip these days. Also same brand can vary in performance due to where they source it from. Generally if you go to a reputable supplier they should be able to advise you accordingly.
587473
Reply By: Bobrovin - Saturday, Jun 07, 2014 at 03:34
Looks like I got a dud lot. I will try again to get better quality.
587474
Reply By: braggy - Saturday, Jun 07, 2014 at 17:05
Hi Bob
The LEDs you put in at home, I'm guessing that they are in those small downlights (that use to be halogen) if so, just check the socket (MR16) as they are only a very small contact point and can heat up/burn.(especially with/after the halogen )
The ones on boards/cards, SMD (surface mounted diode) should not even get warm. The SMDs in my van just lay on the light diffuser.
They will slowly (years) lose light intensity.
Cheers Ken
587475
Follow Up By: Bobrovin - Saturday, Jun 07, 2014 at 22:28
These were the waterproof strips of 5050 with the tape on the back to stick on. They get so hot you can not touch them and after a short time turned brown with heat.
855866
Reply By: Willie - Monday, Jun 09, 2014 at 05:10
For the house I first bought cheap Chinese ones and they were very weak. Then I bought expensive Philips ones and they are great.
I changed all my lights in the van to LED strips and they are working fine.
Willie.
587476
