diesel water filter
Submitted: Sunday, May 17, 2015 at 20:29
ThreadID: 129768 Views:8955 Replies:3 FollowUps:7
Hi all
interested in what water filters in the diesel line that people may have fitted on any vehicle but particularly a landcruiser 200 series what brands what experiences what cost thanks
Stephen & Deborah
Reply By: Gone Bush - Sunday, May 17, 2015 at 21:31
Stephen, I fitted this filter as a pre-filter in my 200 Series.
http://www.ebay.com.au/itm/FUEL-MANAGER-Filter-Kit-FMLC200DPK-Toyota-Landcruiser-200-Series-30-MICRON-KIT-/171357965527?pt=LH_DefaultDomain_15&hash=item27e5bb0cd7
(Once more the "insert link" function is not working for me so you will have to copy and paste.)
It is a 30 micron filter and leaves the 2 micron OEM filter as the final point of protection, as Toyota intended. It stops 99.99% of water but there is also a Water Watch device available that has an audible and visual alarm in the cabin. I didn't fit that device. I figured 99.99% was good enough.
On LCOOL there are some people who have fitted this with a finer 2 micron filter POST the OEM filter. That doesn't make sense to me but to each his own.
Image Could Not Be Found
I hope this helps.
AnswerID: 588663
Follow Up By: Freewheelers - Thursday, May 21, 2015 at 03:25
hi stephen
thanks for that did you fit it yourself
some of the links worked but not all
beats me why some people would think they need another filter after the oem filter
Stephen & Deborah
FollowupID: 856552
Follow Up By: Gone Bush - Thursday, May 21, 2015 at 03:31
Yes, fitted it myself. Dead easy.
FollowupID: 856553
Follow Up By: braggy - Thursday, May 21, 2015 at 17:24
I think you will find Toyota filters are 10 micron.
Dealer advised and fitted mine post factory from new,
no warranty issues or problems
Diesel Care
FollowupID: 856554
Follow Up By: Gone Bush - Thursday, May 21, 2015 at 20:30
The Toyota OEM filter in the Landcruiser is 2 micron. Extra filters are available in a variety of specs. I chose 30 micron and put it before the original filter.
This means that the Toyota OEM filter is still the final protection before the fuel enters the engine, as Toyota intended.
FollowupID: 856555
Follow Up By: braggy - Thursday, May 21, 2015 at 22:15
Toyota diesel filters
FollowupID: 856556
Reply By: Sawtybt - Sunday, May 17, 2015 at 23:18
Stephen,
We also have the same setup in our 200 Series. Filter kit with bracket $359.00 and $318.00 for water sensor.
In trying to keep the interior as clutter free as possible our water sensor has been placed inside the glovebox.Image Could Not Be Found
AnswerID: 588664
Follow Up By: Freewheelers - Thursday, May 21, 2015 at 03:27
hi guys
interesting fit out
your glove box is less in use than ours !!!
Stephen & Deborah
FollowupID: 856557
Follow Up By: Gone Bush - Thursday, May 21, 2015 at 03:34
Just a comment on Ross's photo above. That rectangle with the white label on it is the pollen filter housing. Once my Dealer didn't re-seat the new filter properly and the Climate Control Aircon started to play up, and that was the reason.
FollowupID: 856558
Reply By: grumpyolephartz - Monday, May 25, 2015 at 07:23
I know the question is about 200 Series, but other motors are just as likely to suffer water issues in common rail fuel systems. For the Cummins engines in Dodge Rams, you can get a Fleetguard FS53000 filter, that has two filters in one. The outer element is 5 micron, the inner 3 micron. At $60, not inexpensive Nanonet Brochure
AnswerID: 588665
