Long range fuel tank
Submitted: Tuesday, Aug 18, 2015 at 12:05
ThreadID: 130029 Views:2985 Replies:4 FollowUps:2
I'm considering the need for a long range fuel tank for our F250. Being new and still running in, I'm not sure what the range will be. But I'm picking it may be someware between 400 and 500km in reasonable conditions. Obviously a lot less in sandy stuff.
We are planning to get outback a fair bit and would value advice from some of the old hands about what sort of distance we will be covering between tipical fuel stops.
I guess what I'm trying to ascertain is when does the cost of a long range tank become justified vs a few jerry cans and the frequency of trips.
FTrucks in Perth do a long range tank for Just over $3000
Reply By: GoSeeAus - Tuesday, Aug 18, 2015 at 19:33
Nordave
Try any ARB store and get them to check there Long Ranger series of tanks or search the web and contact Long Ranger direct.
Hope this helps.
Regards John
AnswerID: 589403
Follow Up By: Nordave - Tuesday, Aug 18, 2015 at 20:10
Thanks John, ARB don't have one for the latest F250.
rang Long ranger and they only have one for the earlier model.
FollowupID: 857307
Reply By: MiJule - Tuesday, Aug 18, 2015 at 21:42
We wanted a greater fuel range for our Isuzu Truck and balked at the price of having a permanently fitted tank. We went for one of the farmer/contractor type plastic tanks with there own pump gun hose. 200litres, about $800. Works well. We can take it out if we are only doing short trips and sell it when we finish with the truck. Economical and effective.
Recently we drove from Alice Springs to Geraldton (across the Great Central Road) without refueling. A mix of the contractor tank and a few 60lt drums.
Mike
AnswerID: 589409
Reply By: Muddy - Wednesday, Aug 19, 2015 at 11:22
Hi Nordave,
If your interested in going the way of a 200 litre poly tank with 12volt hand piece
and pump I've got one you can have for around $400 .
I used it for around 18 months then had a custom made 200 litre aluminium tank made to fit across the bed behind the cab in my Ram Truck.
AnswerID: 589422
Follow Up By: Nordave - Wednesday, Aug 19, 2015 at 11:46
That's for that offer Brian, but we are going to be living in the van full time and touring so space on the truck will be at a premium.
So if I do get some thing it would be to fit underneath.
I was interested in the ARB one which is 270 l but apparently it won't fit the later models.
F Trucks from Perth do a 198 l one so may consider that.
Unless any body knows of any others.
FollowupID: 857330
Reply By: Tonca 47 - Wednesday, Aug 19, 2015 at 19:35
Have a look at the long range tanks from Harrison F Trucks. I have seen them in their showroom in Maroochydore.
Peter
AnswerID: 589441
