Landcruiser wheels on a Bushtracker
Submitted: Monday, Sep 07, 2015 at 16:44
130213
3254
Col & Diane
My 2008 BT is towed by a 100 Series TD Landcruiser. When our BT was made we had 100 Series TD wheels (16") fitted, and this required the use of a spacing spyder to compensate for the 60mm offset of those rims. I'm told that the 17" alloy wheels currently fitted to the 200 Series GXL has the same offset.
Has anyone had the 200 Series GXL 17" alloy wheels fitted to their later model BT and if so is the spacing spyder still used, or is some other method used.
Thanks for any replies.
Reply By: Dunrootin Lodge - Monday, Sep 07, 2015 at 21:42
Hi Col & Diane
Our 2006 bt had 5 stud to suit 100 series 16" rims . I put 50mm spacer on to hub then fitted 200 series 17" rims works well hope this helps. John
590106
