Domestic split system air conditioner
Submitted: Wednesday, May 11, 2016 at 17:11
132379
3869
Cook & Chauffeur
G'day all
Just a quick question regarding replacing our rooftop air con (dometic b3000 which we have had repaired and parts replaced on numerous occassions) with a domestic type split airconditioner.
I am thinking of placing the outside unit (weight 28-30kg) at rear of van and inside unit (weight 8-10kg) on an internal wall near the bed.
All up weight is similar to original Dometic b3000 but power usage and associated noise is considerably less (as is replacement cost).
Any thoughts positive or negative are welcome!
Regards Grahame
Reply By: Jeff & Melba - Wednesday, May 11, 2016 at 18:14
Good day
Them split systems may be quieter in side your van but the noise outside is a big pain for any one camped near you. We had a big problem when we had to stay in van park at Longreach,mongrel next door wanted to run the rotten thing all day all night.
599875
Reply By: Bob Bushwacker - Thursday, May 12, 2016 at 17:23
G,Day
Have had a similar experience with the Dometic B3000+. Piece of junk
Have ordered a replacement unit, the new Dometic Harrier inverter unit
These units have not hit the deck yet
If this unit fails, next move will be an Air Command Cormorant
Will keep you posted
599920
